Terra-Dome Earth Shelter Build
   / Terra-Dome Earth Shelter Build #341
This is an awesome project and one heck of a thread on this topic!!:thumbsup:
We have completed 1-2/3 loops of the four. We still need to install the saddles or register vents. We have been using a lot of the 3/4" chip stone at $250 a dump truck load.
Today we got two more loads of 3/4" chip stone and finished gluing the one side of the loop and covered with stone.
   / Terra-Dome Earth Shelter Build #346
It's coming along, Sam.
I was wondering how you will finish the interior concrete? We had plaster put on ours. One thing the plasterer said to do was to paint all the form tie ends with Zinnser BIN primer. This is supposed to keep the rust on the steel from bleeding through the plaster. I think it would work for stains too.
Just a thought.
Dave.
Just a thought.
Dave.
We plan on an acid stain and polish on floors and a special mix for all concrete walls which is white Portland, titanium dioxide and marble dust. The titanium dioxide is what is used as pigment in all paint after lead was removed. It also helps stop mold from forming. The white Portland is the main ingredient and the marble dust also helps to keep it bright white and provides a good filler. This mixture will not be affected by moisture after it dries. It is basically cement and it looks great.
   / Terra-Dome Earth Shelter Build #348
Looking forward to a pic of that wall treatment Sam. How is it applied?
Dave.
   / Terra-Dome Earth Shelter Build #350
It is handled the same as plaster
Thanks. Make sure your floors are 100% covered when the walls are done :) I couldn't believe how much plaster plasterers can throw around. But they taped down a heavy paper everywhere before they started. One thing I noticed, it was difficult for them to true up the concrete surface without having quite a bit of plaster thickness build up around some of the outlet and switch boxes. You can get box extensions if needed.
Dave.
2023 John Deere 6120E MFWD Tractor (A53342)
2023 John Deere...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
NEW 23hp Land Hero Stand Up Skid Steer (A53002)
NEW 23hp Land Hero...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53472)
2012 NEW HOLLAND...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
