Terra-Dome Earth Shelter Build
   / Terra-Dome Earth Shelter Build #341
This is an awesome project and one heck of a thread on this topic!!:thumbsup:
We have completed 1-2/3 loops of the four. We still need to install the saddles or register vents. We have been using a lot of the 3/4" chip stone at $250 a dump truck load.
Today we got two more loads of 3/4" chip stone and finished gluing the one side of the loop and covered with stone.
   / Terra-Dome Earth Shelter Build #346
It's coming along, Sam.
I was wondering how you will finish the interior concrete? We had plaster put on ours. One thing the plasterer said to do was to paint all the form tie ends with Zinnser BIN primer. This is supposed to keep the rust on the steel from bleeding through the plaster. I think it would work for stains too.
Just a thought.
Dave.
Just a thought.
Dave.
We plan on an acid stain and polish on floors and a special mix for all concrete walls which is white Portland, titanium dioxide and marble dust. The titanium dioxide is what is used as pigment in all paint after lead was removed. It also helps stop mold from forming. The white Portland is the main ingredient and the marble dust also helps to keep it bright white and provides a good filler. This mixture will not be affected by moisture after it dries. It is basically cement and it looks great.
   / Terra-Dome Earth Shelter Build #348
Looking forward to a pic of that wall treatment Sam. How is it applied?
Dave.
   / Terra-Dome Earth Shelter Build #350
It is handled the same as plaster
Thanks. Make sure your floors are 100% covered when the walls are done :) I couldn't believe how much plaster plasterers can throw around. But they taped down a heavy paper everywhere before they started. One thing I noticed, it was difficult for them to true up the concrete surface without having quite a bit of plaster thickness build up around some of the outlet and switch boxes. You can get box extensions if needed.
Dave.
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
2005 DRAGON  130BBL VACUUM TRAILER (A52472)
2005 DRAGON...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2024 FORD F-550 SERVICE TRUCK W/CRANE (A52472)
2024 FORD F-550...
