M5040HDC - music in cab
   / M5040HDC - music in cab #1
ITHINKICAN
Gold Member
Fort Bend, TX
Kubota
Kubota factory installed radio w/cd/am/fm/weatherband = $427
or
Buy one aftermarket? It looks like it might be prewired.
Any other creative ideas?
Thank you!
   / M5040HDC - music in cab #2
I just bought an M8540. It came pre-wired and I had them throw in a generic AM/FM weather band, so you can save some money if you can install it yourself.
   / M5040HDC - music in cab #4
or
Thank you!
They do come pre-wired, I went with the w/cd/am/fm/weatherband. I think it was worth the cost.
E/S
   / M5040HDC - music in cab #5
or
Thank you!
From Crutchfield,
JVC KD-HDR20 HD Radio/CD Receiver
Has front aux input.
Easy install. Sounds good
$99.99 Shipping: FREE
   / M5040HDC - music in cab #6
I have the factory stereo, its a decent unit as it should be for the cost! The factory speakers are junk, i blew one moving snow last winter. I pulled the roof & installed a set of 40 watt kickers, 100 % improvement!
   / M5040HDC - music in cab #7
   / M5040HDC - music in cab #8
lawn_king, are the factory speakers in your 3540 mounted in the ceiling? What brand speakers did you buy? As you know the speakers in the B3030 cabbed tractor are mounted very low (behind the seat, stupid location) and aren't the greatest. I'm toying with the thought of replacements and moving the speakers to the ceiling area that other members here have done. I'm electrically challenged in this area. I don't get the + and - when it comes to speakers. Thanks for your info. Stanley
   / M5040HDC - music in cab #9
That's OK, all you have to remember is to wire them up consistently: + terminal to + wire, - terminal to - wire.
The + to - relationship defines the polarity, or phasing, of the speaker.
Generally speaking, all speakers should be wired the same way (i.e., same polarity, working together) for the best sound.
For instance if two speakers in the same proximity are wired up out-of-phase, the sound will try to cancel out at certain frequencies (i.e., fighting each other), and the end result is usually pretty undesirable.
   / M5040HDC - music in cab #10
Ok that sounds (pardon the pun) pretty easy. I thank you.
Allied 760 Loader (A50515)
Allied 760 Loader...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
2025 LandHonor PHA-16-2C Hydraulic 3 Point Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
