M5040HDC - music in cab
   / M5040HDC - music in cab #1
ITHINKICAN
Gold Member
Fort Bend, TX
Kubota
Kubota factory installed radio w/cd/am/fm/weatherband = $427
or
Buy one aftermarket? It looks like it might be prewired.
Any other creative ideas?
Thank you!
   / M5040HDC - music in cab #2
I just bought an M8540. It came pre-wired and I had them throw in a generic AM/FM weather band, so you can save some money if you can install it yourself.
   / M5040HDC - music in cab #4
or
Thank you!
They do come pre-wired, I went with the w/cd/am/fm/weatherband. I think it was worth the cost.
E/S
   / M5040HDC - music in cab #5
or
Thank you!
From Crutchfield,
JVC KD-HDR20 HD Radio/CD Receiver
Has front aux input.
Easy install. Sounds good
$99.99 Shipping: FREE
   / M5040HDC - music in cab #6
I have the factory stereo, its a decent unit as it should be for the cost! The factory speakers are junk, i blew one moving snow last winter. I pulled the roof & installed a set of 40 watt kickers, 100 % improvement!
   / M5040HDC - music in cab #7
   / M5040HDC - music in cab #8
lawn_king, are the factory speakers in your 3540 mounted in the ceiling? What brand speakers did you buy? As you know the speakers in the B3030 cabbed tractor are mounted very low (behind the seat, stupid location) and aren't the greatest. I'm toying with the thought of replacements and moving the speakers to the ceiling area that other members here have done. I'm electrically challenged in this area. I don't get the + and - when it comes to speakers. Thanks for your info. Stanley
   / M5040HDC - music in cab #9
That's OK, all you have to remember is to wire them up consistently: + terminal to + wire, - terminal to - wire.
The + to - relationship defines the polarity, or phasing, of the speaker.
Generally speaking, all speakers should be wired the same way (i.e., same polarity, working together) for the best sound.
For instance if two speakers in the same proximity are wired up out-of-phase, the sound will try to cancel out at certain frequencies (i.e., fighting each other), and the end result is usually pretty undesirable.
   / M5040HDC - music in cab #10
Ok that sounds (pardon the pun) pretty easy. I thank you.
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
LOT LOCATIONS (A51219)
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52128)
2021 John Deere...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
