I'm Looking To Build A Welding Cart
   / I'm Looking To Build A Welding Cart #11
I cheated (cheap) with a 4-Caster 2X2 base-board, and I just set the unit on it! I've got the same 225AC/DC Lincoln Tombstone, and they are a 'Bear' to move around. That's fine for me here at home, with concrete drive and shop. When I take it to the farm, I just set it (Did I say "just set it?", I meant 'wrestle'...) it into in the back of my jeep and leave it there, even during use. I 'fabbed' a 50' cord, back to the power source, that also comes along! Those HF moving dollys are cheap, if that would fit your needs........~Scotty
   / I'm Looking To Build A Welding Cart #12
I have an AC 225, and put it on a Harbor freight rubber tired hand dolly then wound the cords on a hook I put on the dolly, So gloves,, clamps magnets, helmet and cords all on the hand cart, $20. with the rubber tires, I can go over about anything. All that said, I think I am selling it, and keeping the Everlast, 160 amp DC stick Inverter. 20 pounds, and comes with a little shoulder strap. Nicer looking welds anyway.
James K0UA
   / I'm Looking To Build A Welding Cart #13
Welding cart...
Welding cart...
Thanks crbr!! I never thought we'd get clear to page two before we saw a picture of someone's cart.
   / I'm Looking To Build A Welding Cart #15
I've had my new (to me) Lincoln AC/DC 225/125 stick welder for a few months now. The leads are short, so I have to move the welder close to the work. The beast is HEAVY, and it's hard to move. It comes down to this... I need a cart for this welder.
I'd love to see any design ideas that the collective genius of TBN has come up with. What have you done for a welding cart that you liked? What have you done that you didn't like?
I'm hoping to build some storage into my cart. I actually have a small rolling tool chest that I got at a garage sale. I may try to incorporate it somehow.
Here's what I used for my Hobart LX AC/DC stick welder that's about the size of your Lincoln--a $70 wagon from Tractor Supply.
It's large enough to carry the rods and my welding gear.
In the photo I'm welding the skid steer adapter to a bale squeeze I built last year.
   / I'm Looking To Build A Welding Cart #16
:eek: I started to post mine yesterday but it's for my mig. Anyway, here it is in it's unfinished (painted) state.:thumbsup:
I really like the way to keep your ground cord. I'm going to steal that idea.
Looking around on the internet, I saw this cart. It has independent suspension. I'm not sure it's worth the effort or expense for my use, but it's a cool idea...
All Terrain Carts - Specifications
   / I'm Looking To Build A Welding Cart #19
If your welder is one that looks like the tombstone welder, on the bottom back corner of the cabinet on both sides there is a 1/2 inch hole, I used those to attach wagon wheels on mine. I don't remember for sure if I used short bolts for the axles or if I got an axle rod to run all the way across. I used flat bar to make the uprights for the handle and where the little shelf is on the back I put a strap of the flat bar one on each side of that shelf and back to the uprights. I welded the straps to the uprights but it wasn't on my machine when I welded it. I also drilled holes on the bottom of the uprights for the axle to go through. For the handle for it I used a piece of 3/4 inch pipe, and I bent 3 sets of els out of rebar and welded that on to have a place to wrap my cables and to put an extra extension cable on if I needed to reach farther from the power plug. I don't do pictures but I hope you can visualize what I am talking about, it has worked out great for me and is real simple to do, and simple matches me real good. I don't remember what I used to level the front up with, but you probably don't have that particular piece of junk laying around anyway.
For my plasma cutter I used some kind of little cart like I believe harbor freight sells, and for my mig I used an old treadmill frame that someone had thrown out along the road and I put wheels on it and plywood for the deck and an old lawn mower handle for it's handle. I took an eye sore off of the highway and gave it a new and useful life, can't beat that for free.
   / I'm Looking To Build A Welding Cart #20
I forgot to mention on my ac/dc lincoln I tilt the machine back just like you would do a dolly when I go to move it that is why I made the uprights to tilt back to make it easier to tilt and it is real easy to move where you want it.
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
1996 CUSTOM ALUMINUM 16FT CAR TRAILER (A54607)
1996 CUSTOM...
CAT Skid Steer (A50322)
CAT Skid Steer...
2002 CASE 621D XT WHEEL LOADER (A52705)
2002 CASE 621D XT...
