Can you tell me what this is??
   / Can you tell me what this is?? #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
No "Farmers" please. All of you guys know the answer :) Ken Sweet
   / Can you tell me what this is?? #2
Looks like a tow dolly of some sort. Does a narrow front end tractor fit in there when the front tires/axle is removed?
I really grasping here.
You are on the right track, It is a dolly. But it does not go on a tractor. Ken Sweet
   / Can you tell me what this is?? #4
Sweettractors, check your PMs and let me know if I was right when you get a chance.
Aaron Z
   / Can you tell me what this is?? #5
Oh, we feel like the kid in school with his hand dancing in the air wanting to answer the question..... ;)
--->Paul
   / Can you tell me what this is?? #7
It's the thing they tow the airplanes with at the local grass field airport... :)
   / Can you tell me what this is?? #8
For the tires to swivel without hitting something, the mating to the dolly has to be from above, like a gooseneck trailer. Maybe this dolly lets a tractor tow a trailer of some type that doesn't normally hook up to a drawbar.
BTW: Aircraft tow dollies normally only have tires to support the dolly while it is moved into position by the tug. Once the towbar is hooked up, the tires are off the ground and the towbar is supported by the nosegear and the tug. Ken's dolly is made to support weight on the tires.
   / Can you tell me what this is?? #9
Ahh- basic description " Low speed bolt on hitch dolly"
Jinman, You are getting awful close. Just need to know the implement? :) Ken Sweet
1974 Ford F600 Grain Truck (A56436)
1974 Ford F600...
2016 Nissan Sentra Sedan (A56859)
2016 Nissan Sentra...
2011 Toyota Prius Hatckback (A56859)
2011 Toyota Prius...
Bobcat S740 (A57148)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
