Another "myth to kill"??.....what makes it go???
/ Another "myth to kill"??.....what makes it go??? #1
AKKAMAAN
Port Angeles WA
Here is another "challenge" to all of you....
Have you ever heard about "flow makes it go"??
IS IT A MYTH??
Can you guys tell me your "take" on this one??
/ Another "myth to kill"??.....what makes it go??? #2
Make what go?:confused:
Oh sorry Transit....this is obvious when you have once come across this saying "flow makes it go"....
You are a lucky guy if you never heard about it.....:D
It relates to the hydraulic cylinder, motor or what ever hydraulic actuator there is to move....
/ Another "myth to kill"??.....what makes it go??? #5
Pressure makes the flow make it go.
Bruce
/ Another "myth to kill"??.....what makes it go??? #6
gpm gives you speed and psi gives you power. Of course a lot of other factors must be considered, but as a general rule thats the case.
/ Another "myth to kill"??.....what makes it go??? #7
differential pressure causes it to move ... moving allows flow
Hint...
Newton's first law of motion.....
"Every object in a state of uniform motion tends to remain in that state of motion unless an external force is applied to it."
/ Another "myth to kill"??.....what makes it go??? #9
:thumbsup:....
/ Another "myth to kill"??.....what makes it go??? #10
Having had to troubleshoot many hydraulic problems over the years, flow by itself won't do any work. It is the ability to make flow under pressure that does the work. I have tested many hydraulic pumps with a flowmeter that would make the recommended flow with no pressure, but as soon as you introduce a restriction, that flow it would drop to nothing. Most pumps are rated with a static flow at a given RPM and are expected to still flow at least 80% of that, up to the system relief pressure. Which also shows that pressure alone won't do any work, considering with the same flowmeter I can stop the flow and still have pressure.
Brian
/ Another "myth to kill"??.....what makes it go??? #11
Area is implicit of course.
/ Another "myth to kill"??.....what makes it go??? #12
I will say yes. Of course pressure is needed to overcome the load. If I remember right, a pumps job is to produce flow primarily, and pressure is secondary.
Pressure that has no flow= no work, but potential work.
/ Another "myth to kill"??.....what makes it go??? #13
If the river is flowing the Ram pump may be pumping as well as waterwheels turning various equipment.:D
But mainly it seems to be the state of the energy and it's application.:thumbsup:
hint#2....
How can objects (a load) move where there is no "flow" available???
/ Another "myth to kill"??.....what makes it go??? #15
hint#2....
They can't.
Brian
edit- Back to the original question. Flow alone can make it go as long as as there is no resistance or load.
/ Another "myth to kill"??.....what makes it go??? #16
hint#2....
Parasitic, weight, and leakage.(or a damned good magician!)
They can't.
Brian
yes objects can move with out flow.....it happens all the time...my wheel barrel moves without hydraulic flow....and so do everything else that moves from just a force....
read Newtons first law again.....only force is required to move an object....
/ Another "myth to kill"??.....what makes it go??? #18
If no flow, then no go. You could have pressure, you could have volume, but if the fluid is not moving, you have a static situation, such as an accumulator. The potential for work is there. A weighted load is another way to push fluid, and could exceed the pressure of a pump. When you ram that bucket into a dirt pile or a stump, the back pressure could exceed the pressure rating of any component in the hyd system.
/ Another "myth to kill"??.....what makes it go??? #19
hint#2....
I thought we were talking hydraulics here.
{ Wheel barrel } ?
/ Another "myth to kill"??.....what makes it go??? #20
Depends on how "Slippery the Slope" is!:thumbsup:
JOHN DEERE 3032E TRACTOR (A60430)
JOHN DEERE 3032E...
2018 INTERNATIONAL LT625 TANDEM 6X4 SLEEPER (A59904)
2018 INTERNATIONAL...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
