Repair holes in metal roof?
   / Repair holes in metal roof? #1
jfh0jfh
EC Ohio
Kubota MX5100, JD 710, Case 450
I'm putting used metal on a new storage barn. There are (of course) holes in the used metal. Some too big (nail-head sized) for silicone (my usual method).
I thought of using regular tar but saw here a thread on using Henry's and Elastomatic.
Anyone have any experience w/ these or similar products, specifically w/ larger holes?
(I realize that used tin will be a poor economy if I have the continuously patch the roof. New metal would be ~ $1350 and I have a lot of used tin.)
Thanks. Flashing is usually AL but I take your point. I think though that there are too many holes to patch. I'l patch rips but if I have to patch nail holes I'll be better off buying new metal.
Make up patches out of roof/gutter flashing and glue them down w Henry212.
   / Repair holes in metal roof? #4
I used silicone to fill some large nail head size holes in metal roofing and it's held up fine for 2 yrs. Just smear it on and if need be put a second coat on it.
   / Repair holes in metal roof? #5
Depending on the pitch of your roof you should not have to worry about nail holes...I had an old barn with a metal roof at a tenant house I wanted to tear down for years but every tenant begged me to leave it...I told them about the nail holes in the roof and they all said it did not leak...I finally went over durring a thunderstorm and stood in the barn with the tenant and sure enough ...no leaks..I don't remember the pitch of that roof but the water runs off fast enough apparantly...I would just wory about any open gashes that you have ..Check the big box stores ..use black jack and some old shingles...keep it simple...that is what I would do..but what do I know..? :)
Thanks for the advice. This tin is from a later building where the fasteners were in the flats instead of the ribs. This seems a poor method to me but around here tin makers won't honor the guarantee unless fasteners are in the flats: per them, fasteners in the ribs crack the metal.
It's a 4/12 so steep enough to run off as you suggest (I have a < 3/12 w/ unsealed nail holes in the rib and it doesn't leak). I may just put it on and see but I want to be able to seal if need be.
   / Repair holes in metal roof? #7
If you decide to use Silicone , make sure it is Neutral cure , not the regular stuff that is Acidic cure as the latter will corrode a hole through the sheet in a few years .
   / Repair holes in metal roof? #8
i have done this before. use a washer and rubber washer nail. silcone spot first then drive the nail with washer. never had problem.
   / Repair holes in metal roof? #9
Have you tried putting rivits in the holes. Different sized rivets depending on the size of the hole. I sell used tin from time to time and this is what I recommend when someone asks about filling the nailholes. Anything with a bigger hole that cant be covered by a rivet needs a patch rivited over it.
   / Repair holes in metal roof? #10
If holes too big for rivets, than maybe bolts/nuts with rubber washers and/or fender washers with silicone squirted under them.
Have to consider cost of materials and labor putting them on, but may help the shed the rain.
   / Repair holes in metal roof? #12
Someone on Farm Show Magazine advertized 1-1/2" round aluminum disks with an elastomeric adhesive backing that would form fit to corregated roofing. Seemed reasonably priced & easy to apply. I have a similar roof yet to be plugged. I'll try to find a name/website. MikeD74T
   / Repair holes in metal roof? #13
My detached garage has a tin roof that must have been recycled metal. It leaks.
I'll have to try some of the suggestions on here. I think I'd be able to silicone the holes. I doubt any of them are too big.
   / Repair holes in metal roof? #14
Sold over here as electrical sealant. Or electrical grade RTV.
We also have a Neutral cure Silicone branded "Roof & Gutter" .
Just another snippet of info I learned in the school of Hard Knocks , never use Galvanised roofing/nails or screws with Zincalume guttering/down pipes/tanks etc and vice versa as the chemical reaction between the two dissimilar metals will rot one or the other out as the water runs over them , just as quick as Acidic cure Silicone will .
   / Repair holes in metal roof? #15
I have used a caulk called "through the roof" several times, with complete success. Google up through the roof caulk. I like it much better than silicone or blackjack.
   / Repair holes in metal roof? #16
..... where the fasteners were in the flats instead of the ribs. This seems a poor method to me but around here tin makers won't honor the guarantee unless fasteners are in the flats: per them, fasteners in the ribs crack the metal.
I have installed 3 metal roofs on different builds. Around here the lumber yards almost all stock Fabral brand. The installation instructions call for nails to be one the ribs and the screws to be on the flats. I have used the screws exclusively and not had any issues with them being on flats.
You might want to check them out on the web. If my crusty mind is correct they have a number of different screws, all with neoprene washers, for different applications. Maybe if you are lucky one of them will have a large enough washer to seal the hole.
If you use screws in new locations do yourself a favor mark and drill them on the ground. Take a couple vise grips or c-clamps, with rags to prevent scratches, and pinch the sheets all together, mark them with a sharpie, and drill them before putting up. This makes it easy to s-t-r-e-t-c-h and drive the screw in. Magnetic driver required. Good Luck.
Thanks to all for the comments. This was really helpful. I have the old 40x80 building down (it collapsed under our Feb-2010 snow) and I think I'm in decent shape: I'll be able to cut the nail holes off the ends the old tin and have some decent sheets to install.
I'll try to summarize here rather than post separate replies:
- I didn't know there were two kinds of silicone cures. I'll get neutral-cure if I go that way.
- I'll look into the various caulks.
- Home Depot has (5-gal) Henry's $72 and Elastometric (sp?) $55. Oddly Lowe's doesn't have either.
- I have a lot of extra tin so I won't try to patch holes/ cuts. Those can go on the side away from weather.
- I will be using screws. Working by myself they're easier than nails.
- Re the gent who suggested drilling: what I usually do is put 5 sheets together and punch a line. It penetrates the top 3 anyway and leaves dents in the rest. But this is tricky as I used some cull lumber opn the rof and looking down the purlins it's a bit like spaghetti. I hadn't thought of drilling. I'll try a couple of sheets and see.
- I didn't know there were different kinds of sealing washers on nails/ screws.
- Bolts w/ gasket and/ or rivets are a good idea for larger holes.
- Sealing under a screw/ nail isn't an option for the old holes as my purlins are 2' OC and the other gents seem some semi-random 1-meter+ OC starting in the center. I'm using his wall tin on my roof.
Hope I didn't miss anything. Thank you all again.
   / Repair holes in metal roof? #18
I was just reading this post and am doing a bit of metal roofing myself and learned the hard way how to cut the panels.
I wanted to pass this along, and maybe save some people from troubles. I use a circular saw with a metal cutting blade. (aval at walmart 5 bucks for three). When you finally cut Ive found that I secure the panel with a clamp and then start the cut and move the saw backwards.It cuts great this way. I found going forward it would bounce ,as it tried to be pulled up into the saw.
So much like cutting with a backwards mounted blade on a saw for vinyl siding ..
   / Repair holes in metal roof? #19
I've been using a newer (?) type of caulking recently called thermoplastic. Sticky as all getout and will stretch with thermal expansion, plus it will stick to itself, whereas new silicone won't stick to old silicone. Sticks to brick, steel and wood just like urethane....
Gonna try it on my woodshed nail holes (steel off my garage)
   / Repair holes in metal roof? #20
I have just had a new metal roof put on a metal garage and I had the type of roof changed. It originally had an A type roof and had the metal with the ridges running the length ways of the building. Where the metal overlapped the people that put it up never used anything to seal between the metal joint and water ran in between the metal and rusted holes out in it where the metal overlapped. That roof lasted about 4 years and I thought I was having condensation problems but when I took the insulation down I saw what the problem was.
The roof now is a slant roof that runs the water all off on just one side and I have an overhang all the way around the building. The ridges of the metal run from the eve to the top on about a 3 1/2 to 4 roof pitch.
Now to my question, where the old roof rusted the rust stain ran down the metal on the sides of the building on the inside of the metal. I can clean the stain off but I want to also primmer it and put a finish top coat on the inside side of the metal using rustoleum paint. I have a gravity fed sprayer that I can use to put the paint on with but rustoleum is an oil based paint, it said to use acetone to thin it with and to clean up with, if I use my sprayer can it be cleaned up so that I can later use it to spray automotive paint? Is the factory paint on the underside of the tin as durable as the outer paint on the tin?
Some on tbn mentioned that my having a steel frame may have had some part on it rusting through so quick [but in this instance I don't believe is the case], however I used pressure treated wood and boxed around all of the roof framing and I intend on doing this for the walls also before I re-insulate it. When I took down the insulation there was absolutely no condensation on the metal roof, I have a plastic vapor barrier in it and that would catch the water from the holes and when it built up enough it would start dripping. I hope someone knows for sure about my spray gun. Sorry for being so long winded, the next reply hopefully is shorter.
2013 BMW X5 AWD SUV (A59231)
2013 BMW X5 AWD...
Deere 35P (A53317)
Deere 35P (A53317)
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
TANK MANIFOLD (A55745)
UNUSED FUTURE TBS20-20" HYD TELESCOPIC BOOM (A60432)
UNUSED FUTURE...
2382 (A60432)
2382 (A60432)
