1/4" Valve Haters---Read This
   / 1/4" Valve Haters---Read This #1
Giles
Florence Alabama
2009 Kubota B2320---Wheelhorse lawn mower--- Case 480D Backhoe
I recently bought my first Kubota--2009 B2320HSD. Since this machine was purchased used, I have no idea about the history.
I have participated in threads on 1/4" valve operation and although this type system is new to me, I understand how it is supposed to operate.
NOW---My owners manual states that this model, B2320HSD has the 1/4 inching valve, and mine DOES NOT!
The B2320DTN-1(narrow) has position control. The scale for the DTN lift, is numbered where mine only has arrows and two adjustable stops.
My B2320 definately has position control and I do not understand why:confused:
Could it be possible that the previous owner of this tractor made modification to the 1/4" system to make it position control:confused:
I have no problem with the lift operation on my tractor but I know some of you dislike the 1/4"ing system. This post is mainly for you in that something may be possible to modify the lift system if desired.
   / 1/4" Valve Haters---Read This #2
The B2330 Narrow was primarily intended for nurseries, tree farms, and other commercial use. They come factory equipped with position control, and also a slightly higher lift capacity than the regular B2320 IIRC.
   / 1/4" Valve Haters---Read This #3
My B3200 is suppose to have 1/4 inching valve for the 3PH and I bought it new. I can't seem to make it work but I assume it is opperator error.
Anyone willing to tell me how it works?
   / 1/4" Valve Haters---Read This #4
Also for use in vineyards where the width between rows of grape vines needs to be minimal in order to maximize production.
   / 1/4" Valve Haters---Read This #5
The full range of travel control is between the stops on the control setting at the handle / lever. By default position, the handle / lever is positioned to the outter direction of the travel path of said lever. When you grab it to implement movement, one just moves it forward or back (up and down) without thinking about the lateral position. Thus the oversight of the feature.
Move the lever in (laterally) toward the driver and use that position and the normal range of motion (for up and down) for the 1/4" movement. Be patient as it is a bit slower in motion than the open position movement (default position).
   / 1/4" Valve Haters---Read This #6
Excuse my stupidity, but pull the lever in toward yourself and then push down while holding the lever toward yourself and it will move 1/4 inch at a time???
   / 1/4" Valve Haters---Read This #7
Yes Sir. Or you may so choose the up direction as well. Not in 1/4" (stop and go) increments but at a slower rate of movement allowing for ~ 1/4" (slower) movement vs the full speed of the other position.
Best I can tell, that is how the movement is conducted. I sat on mine for a long time looking for the trick to the 1/4" feature.
   / 1/4" Valve Haters---Read This #8
There is also a good chance that the stops on the lever guide were not set properly from the factory. You will notice on the stops there are two 'steps', the one closer to the operator is for 1/4", the outer one moves the 3pt hitch at full speed. If you are pulling it against the inner stops and it doesn't move very slowly you need to loosen the little nut on the stops and move them closer until it does. When it is set properly you should be able to give the lever a quick 'bump' against the inner stops and it will only move a 1/4" at the lower link end. Also you can hold it against the inner stops and it will move slowly, or hold it against the outer portion of the stops and it will move quickly.
   / 1/4" Valve Haters---Read This #9
Nice explanation, I'll be adjusting mine, Thank you!:thumbsup:
   / 1/4" Valve Haters---Read This #10
Hey guys there has a been a recent discussion about the 1/4"ing set up lately in another thread. Here is a link to it, go thru the whole thread because the are some other links in it about the set up.
http://www.tractorbynet.com/forums/kubota-owning-operating/180169-new-b2620-problems-2.html
I aslo included a quick picture of what is being mentioned about moving the 3pt handle out (away from driver) and around the 1/4"ing stop to move the 3pt faster.
Sorry this is the link with the rest of the info with the extra links in it:
http://www.tractorbynet.com/forums/kubota-buying-pricing/180412-eat-my-words-about-1-a.html
Good Luck Everyone ! :thumbsup:
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2010 LACROSSE LUXURY LITE TOURING EDITION TRAVEL TRAILER (A50854)
2010 LACROSSE...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
Komatsu PC138 (A50490)
