Backing up a trailer
   / Backing up a trailer #1
ShenandoahJoe
Gold Member
Shenandoah County, VA
Kubota B7300
I have a little 4'x6' trailer that I use as a general-purpose farm cart, drawn by a ball hitch on my drawbar. It works great going forwards, but it's easy to jackknife going backwards. Now, I have the lower arms of my three-point hitch held out of the way with bungee cords, but I got to wondering if I might be missing an opportunity here.
Is there a way to rig some kind of check chains off the arms, which can help hold the trailer straight when I want to back up?
   / Backing up a trailer #2
Your right, it is a good opportunity. it is a great opportunity to learn to back a trailer. The shorter the trailer, the more difficult it is but I know you can do it. Just go slow.:thumbsup:
   / Backing up a trailer #4
a little 4'x6' trailer <-----------
That's the problem right there.
My welding trailer is short, too and it's a :mad::confused2::(:ashamed::mad: to back up in a straight line. Just takes time and patience and a few kind words.
   / Backing up a trailer #5
I...........
Don't think you want to do that.
Practice, practice, makes ........:D
Then when you have that down, try a 4 wheel wagon. :)
Then after that, a four wheel wagon behind a two-wheel chopper or baler. :) :)
Then, this same rig 200 yards down a narrow fenced lane that has no gate at the end, with a JD G with hand clutch and no power steering. And it was a hot day too.
   / Backing up a trailer #6
It will be "less difficult"; won't use the word "easy" if you lengthen the tongue. Some fine it less difficult to back by using a 3-point hitch as opposed to the draw-bar. There simply is no easy way to back one of these up, but with practice you should be able to do OK.
As mentioned, try a four wheel cotton trailer etc:(
   / Backing up a trailer #7
You win.
   / Backing up a trailer #8
Hook that short trailer to an ATV and it will be even more fun. As said the shorter a trailer is the harder to back up.
   / Backing up a trailer #9
Better than check chains would be pallet forks and just pick that little feller up by backing the forks under the rear of the trailer. Would go equally well in either direction.
   / Backing up a trailer #10
It should be a LITTLE easier if you get the ball off the drawbar and put it on the 3pth which will be farther out to the rear and give a bit quicker response when you turn the wheel....Other than that a longer trailer tonque (or pallet forks) is the way to go.
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
Utility Trailer (A52377)
Utility Trailer...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
