B7335 light kit for the B2320
   / B7335 light kit for the B2320 #41
to bxowner: thanks for the idea of using the turn signal switch to control auxiliary lighting. I have little use for the turn signal lights so I pulled/swapped a few pins on the back of the switch harness and tied it in with my worklight wiring. Now I slide the switch forward to activate front worklights and slide the switch to the rear for the rear lights. Middle switch position - no lights. The emergency flashers continue to function normally which is a good thing, of course.
I too, would be interested in obtaining just the bracket and u-bolt for the B7335 light kit. Does anyone know if this is doable?
   / B7335 light kit for the B2320 #42
Absolutely. Price is around $70 for the u-bolt and bracket. In other words, the complete kit is a better buy.
   / B7335 light kit for the B2320 #43
I could use some help here;
I am wondering about the posts regarding the lights being in the way (head clearance)...since my ROP (BX 2660) is no where near where my head is while sitting on the tractor.
Think two of these kits are too big for a BX2660 ?
Could I get the rough dimensions ?
Are the brackets perhaps too big for the BX2660 ROP ?
   / B7335 light kit for the B2320 #44
you can make a bracket if you can weld
   / B7335 light kit for the B2320 #45
you can make brackets like that for about 10 bucks with some plate steel paint and u bolts! i put two lights on my B 2620 for about 50 bucks! thats including a waterproof switch, lights, wire, wire loom, and brackets. o and about 2 hours of work/fun:laughing:IMG_0149.jpgIMG_0149.jpg
   / B7335 light kit for the B2320 #46
Alot of good ideas and projects on this thread. My question concerns the wattage pull from two 50 to 55 watt lights. I have a new Kubota 3200 and plan on using two front facing round Blazer par 36 lights (haven't purchased them yet and none of the specs list the bulb wattage so I'll assume they're approx. 50 watts each) and one rear work/fog light with seperate switches. To anyone who has already completed their project; are any modifications needed to any part of electrical system (ie- alternator, fuse box, etc.) to run this setup?
John Deere L118 Automatic 42in Riding Mower (A51694)
John Deere L118...
1274 (A50490)
1274 (A50490)
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
