ford 1700
   / ford 1700 #31
Jc:
Thanks. I questioned the fact that he said it had live pto. I left a message for him to contact me back, however, he hasn't replied as of yet. Yes, I do know how to check. So, the dual clutch was an option, but no one on the forum has one. Interesting. He said this was owned by a cementary and they had a three point hitch finish mower on the back. It does not have a draw bar. So, the motor has 1805 hrs on it but probably not hard hrs since it was used for mowing. Let me know your thoughts. Thanks.
1210 man.
   / ford 1700 #32
Jc:
1210 man.
1210,
Why mentioning a draw bar?:confused: is there any significance there? I suppose it has the lift arm and the top link? are you saying that the lift system was not used much?. I suppose long hrs of easy mowing can add up quick. Now, is this guy works for the cemetery or he bought it from them. I have seen on 1700 that had 3800 hrs on it and still worked pretty well. guys here have them with up to 2500 hrs and no one complained about bad performance. couple of guys ended up overhauling the engine for different reasons but neglect could have been the culprit. any pics? and how much is he asking. condition of the rig can leave tell tale sign. I'd give it a good once over. Major parts can be expensive (internal engine) but the rest can be pretty easy to be had and it is extremely cheap to operate it.
JC,
   / ford 1700 #33
It has lift arms, however, I find myself sometimes needing a draw bar to pull things around. He said it came from a cementary and he does not work for one. He is asking two thousand dollars. From the pictures it looks almost new. No bent tin, turf tires are in excellent shape, all lights and guages work and he states it does not smoke. I'm looking at it due to the fact it would be a good sized tractor to put a snowblower on to get into some tight areas I have. The price just seems too good to be true and I'm waiting to hear from him concerning the pto (does it have a double clutch or not).
   / ford 1700 #34
You can buy a draw bar from TSC under $25 but you'll need a top link connection or something to keep the draw bar from rotating. Price is very good, for single clutch, it would be marvelous for double clutch jobby. Is your snow blower pto powered? a contraption like below and a hitch ball is all you need. I'd give a good once over to make sure everything is up and up before I buy it. It sound way too good.
Jc,
   / ford 1700 #35
Have an early 80's model 1700 4WD. It has been a workhorse. I was looking to buy a 3 point wood splitter attachment but didn't see anywhere to hook up to the hydraulics on the tractor. Anyone know how this is done?
   / ford 1700 #36
Welcome to TBN Blue:)
You'd need a hyd block as pictured to have a have a supply and a return path for your wood splitter.
On the cheap, probably you'd be able to cut the discharge pipe close to the pressure relief device, and tee off for a compression type connection. For return you can tie it to a return port to the diffy directly as the pic below. I personally would not cut in the discharge pipe and would rather get a proper block.
Notice the banjo fitting on the 3rd picture. I myself looked to see if I can get a longer banjo bolt and fitting to branch off right at the existing connection and have not been able to find it.
JC,
   / ford 1700 #37
JC,
Wondering if using the longer banjo bolt would cause problems, since the pressure would follow path of least resistance. I think I'd run a power beyond joystick, with the power beyond port powering the 3 point circuit, and use the pipe threaded port shown as the dedicated return for the loader valve.
   / ford 1700 #38
True enough chumly on the path of least resistance. Flow at the banjo at the best is pretty turbulant so I don't think it is a major issue here. I have seen double banjo being used on different applications and seen catalog on them. Power beyond kit is a superior choice, mine was a budget option:D.
JC,
ps. Now below is the super economy remote right of the lift cover. it just take a 3/8" hyd hose for under $10 from TSC. it does have the added advantage of using main lift spool valve without buying another spool. Obviously both 3 point and the added implement will be operated by the same valve. if nothing is on the 3 point then that extra hose acts as dedicated power beyond. not a great set up but totally utilitarian.
   / ford 1700 #39
i bought a new 1700 ford over 30 years ago has been an awesom very dependable tractor.hard to find parts for it.23h.p. after30 yrs. of heavy use inow need a steering box assy. anybody know where to look
   / ford 1700 #40
a salvage yard like gulfsouth equipment in baton rouge la. or western kentucky tractor parts in kentucky cant think of the city name
2022 CASE 850M LGP CRAWLER DOZER (A52709)
2022 CASE 850M LGP...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
SANDBAG ATTACHMENT (A58216)
SANDBAG ATTACHMENT...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
Ford Dully Bed (A57453)
Ford Dully Bed...
1 BOTTOM TURN PLOW (A58375)
1 BOTTOM TURN PLOW...
