I added one of those to my PTO shaft to make my life easier hooking PTO powered equipment.
). I have read (probably here on TBN) PTO extenders can result in premature wear on the tractor's stub shaft bearings. I have no idea if that's true and I still use my extender when hooking up my chipper (Woods chippers come with very short drive shafts).[/QUOTE said:of course its harder on the tractor pto bearings. It moving the heavy u-joint assembly farther out from the tractor which gives it more leverage. There is always some wobble in a pto shaft( thats the only way you can hook it up easy) and the further that heavy wobble point is away the harder it will be on it.
Anytime you put a solid extension on a shaft your increasing leverage at its stationary point.
With these aluminum tractor casings i would never use an extender unless absolutely necessary, and then i'd still be very careful.....
I can't tell from the pics (and I'm not familiar with that part) just where the crack goes. Would that crack go through a bore or pass through any other machined mating surface? If it does, then welding would have be followed up with some machine work to true up those surfaces. If it's just cracked through the case, then it may be possible to glue it back together with some Ni99, Super Missle, or stainless steel rod & TIG welder.
If it were mine, and it the crack was in a weldable location, I wouldn't hesitate to try to weld it back together. What's the worst that can happen??? you screw the piece up and have to buy a replacement?
Even when you lower your 3PH completely? The 3PH is lowering completely, is it not?
For those of you who don't know, there are four types of cast iron:
Grey, white, maleable and nodular. White is not weldable but the rest are.
Note that some manufacturers use cast steel, not cast iron. When
carbon content drops to 1.7% or below it is steel (cast irons are
typically 3-4% carbon). We don't know what the manufacturers are
using.
Cast steels are stronger than cast irons, but somewhat harder to cast.
I have never tried welding cast iron or cast steel myself, but I will try the
ER70S wire the next chance I get.
DF,
Here's a cast hook I mounted to my 300CX (steel) bucket. I've also welded teeth to my BH and repaired cast arms for bailers.(Millermatic 210)
Rob
I would doubt that the hook is cast.... most are forged.
All the hooks I buy are forged, and they usually say so on each one.
Rob's hook definitely looks cast, however. It has the grinding marks
along what seems to be the mold parting line.
