JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Steeper than it looks and mushy due to the vegetation holding the water. Maybe a bit of sand and gravel after you get it mowed. That is a flail on there isnt it?
larry
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
The rear tires are R4 slicked up with mud! The implement on the back is a box blade pretending to be an anchor. That particular area of the pond is pure sand but I slide so far in that I got into the clay a bit. A pure recipe for stuck if ever there was one.
I had to get a skid steer over because the flat on top of the bank is very short and then the forest starts. The problem we had was the rears of the skid steer would come up off the ground when we tried to pull and we'd lose traction. It took patience, perserverence and two shovels to get her out.
What happened was I like to keep that bit of the bank clear. Every now and again I grade it with a rear blade. This time I went back too far because the box blade is not near as far out behind as the regulat blade. The wheels sank in, the tractor was bottomed out, the blade was embedded. A perfect setup if I do say so myself.
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
I saw a late 60's Case backhoe in that situation when I was surveying on a highway job. The operator asked a D10 Caterpillar to back down and give him a tug with his winch. The guy wrapped the cable around the front axle and gave the D10 operator the nod. Next thing we saw was a couple of gallons of engine oil spilling from the cracked block. Turns out the engine held the Case front end to the back end. The suction of the muskeg was more than the casting could handle, though the D10 didn't care, either way.
Last I saw of the hapless backhoe operator he was walking over the hill on his way home. He knew he was finished.
Great pics Jimmy, and thanks for sharing. I did something similar yesterday with my riding mower. The closer you get to the water, the nicer the results, but sometimes, you get just a little too close. The first year that I started mowing around my pond, I got stuck every single time!!!!!!!!!!!!!
I stuck mine in the pond twice last year. Both times I was just barely able to get out with the loader. I was further in, the ground was almost level but deceptivly wet, because the water was very low the banks are just as steep but higher. I had made a ramp for entering and exiting so there was only one way out wrecker or no.
I know about the pucker factor.
Something similar happened to me a few years ago with my Massey 35. The front wheels got stuck real deep in a mud hole by the sea side. I used a jack and planks, but never managed to get out. The trouble was the tide was coming in and I had not much time left before the tractor was under sea water. After breaking a chain from my bush hog twice (not very strong but it was all we had), the neighbour's big agricultural tractor finally pulled me out in time.
