Massey 135 Front End Rebuild
   / Massey 135 Front End Rebuild #1
moparman
The front end on the Massey 135 I purchases last year is need of a rebuild. The spindles on each side travel up and down about a 1/2" in the axle extensions. I don't think the main axle has much play in it, it just seems to be the spindles on each side. Can I just replace the bearings and bushings in the axle extension? Where is the best place to purchase these parts? Thanks
   / Massey 135 Front End Rebuild #2
Do you have the detroit or UK model?
Detroit Model I think
   / Massey 135 Front End Rebuild #4
G,Day moparman.
up and down?.
Do you mean that both the front axle king pins
slide up and down the king pin is the part that has the stub axle on the bottom and the steering arm on the top which the steering rod attaches to?? .
If this is so undo the pinch bolt that secures the steering arm to the king pin use two ring spanners ,this is a clamp arrangement ,undo the bolt about one turn will do and tap the steering arm down till it just touches the top of the axle then tighten up the clamp bolt ,last grease the whole tractor .
Happy days .
Hutch.
2017 Ford F-550 (A55973)
2017 Ford F-550...
203201 (A60429)
203201 (A60429)
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
294 (A52706)
294 (A52706)
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
