Front End Loader on a 2WD Tractor?
   / Front End Loader on a 2WD Tractor? #1
MBDiagMan
Gold Member
Sumner, Texas
John Deere 5045D, Grasshopper 61" with PowerVac,Gator 825i, Cub Cadet 2145
I am getting mixed feedback regarding the usefulness of an FEL on a 2WD tractor.
The tractor will probably be a 4005 JD or M5100 Kubota 2WD. I will be using the loader for moving gravel, brush and timber with very little actual loading of material onto a truck.
Thanks for sharing any experience that you may have regarding this issue.
Doc
   / Front End Loader on a 2WD Tractor? #2
We have 85 hp loader tractors at each facility and 1 more on the farm. All 2 wheel drive with FEL and no problems. What did people do before 4 wheel drive? Ken Sweet
   / Front End Loader on a 2WD Tractor? #3
My experience with 2WD and FEL has been pretty good. As long as the tractor has power steering. I used my tractor/FEL combo for a few years without the PS working, and it was a real work out. But now that the PS is fixed I've moved many loads of "Stuff". I've move 30 or 40 trees with the Grapple, dug and moved dirt with the bucket, etc.
The one thing you WILL need is balast. Either loaded tires or something heavy on the back.
Wedge
   / Front End Loader on a 2WD Tractor? #4
You should avoid 2WD with FEL if you will be operating on slopes.
   / Front End Loader on a 2WD Tractor? #5
Before the mid eighties, there were no 4 WD in this area of the state. Now, You see one occasionally. Not a common sight in Central KY. The exception is the smaller CUT and SCUT's. Ken Sweet
   / Front End Loader on a 2WD Tractor? #6
I had a 2wd old Oliver with a loader for 10 years, it will work but as said before, use a ballast in the back and do not forget that when you have a bucketfull, your braking ability will be reduced a lot . Less weight on the back means almost no braking......now I have a 4wd and love it... you will learn why you have 2 braking pedals:D. Good luck.
Thanks for the quick and thorough responses.
I live on pretty flat ground. There are some sloping areas on the place, but mostly flat ground.
Thanks again!
Doc
   / Front End Loader on a 2WD Tractor? #8
I use a FEL on a JD 5103 with PS 2wd in Ga.with no Problems at all. On a small compact you will need ballast if it doesn't have PS or 4wd. you won't be able to hardly turn the wheel without moveing and the weight in the bucket you will loose your Drive Traction without any counter weight. If you are on alot of a Grade or Hills 4wd is almost a must. IMO.
Carey
   / Front End Loader on a 2WD Tractor? #9
If resale value is at all important to you, then get 4WD.
   / Front End Loader on a 2WD Tractor? #10
My old 4010 2wd
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 5075E (A53317)
John Deere 5075E...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
17102 (A56859)
17102 (A56859)
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
