Front End Loader on a 2WD Tractor?
   / Front End Loader on a 2WD Tractor? #1
MBDiagMan
Gold Member
Sumner, Texas
John Deere 5045D, Grasshopper 61" with PowerVac,Gator 825i, Cub Cadet 2145
I am getting mixed feedback regarding the usefulness of an FEL on a 2WD tractor.
The tractor will probably be a 4005 JD or M5100 Kubota 2WD. I will be using the loader for moving gravel, brush and timber with very little actual loading of material onto a truck.
Thanks for sharing any experience that you may have regarding this issue.
Doc
   / Front End Loader on a 2WD Tractor? #2
We have 85 hp loader tractors at each facility and 1 more on the farm. All 2 wheel drive with FEL and no problems. What did people do before 4 wheel drive? Ken Sweet
   / Front End Loader on a 2WD Tractor? #3
My experience with 2WD and FEL has been pretty good. As long as the tractor has power steering. I used my tractor/FEL combo for a few years without the PS working, and it was a real work out. But now that the PS is fixed I've moved many loads of "Stuff". I've move 30 or 40 trees with the Grapple, dug and moved dirt with the bucket, etc.
The one thing you WILL need is balast. Either loaded tires or something heavy on the back.
Wedge
   / Front End Loader on a 2WD Tractor? #4
You should avoid 2WD with FEL if you will be operating on slopes.
   / Front End Loader on a 2WD Tractor? #5
Before the mid eighties, there were no 4 WD in this area of the state. Now, You see one occasionally. Not a common sight in Central KY. The exception is the smaller CUT and SCUT's. Ken Sweet
   / Front End Loader on a 2WD Tractor? #6
I had a 2wd old Oliver with a loader for 10 years, it will work but as said before, use a ballast in the back and do not forget that when you have a bucketfull, your braking ability will be reduced a lot . Less weight on the back means almost no braking......now I have a 4wd and love it... you will learn why you have 2 braking pedals:D. Good luck.
Thanks for the quick and thorough responses.
I live on pretty flat ground. There are some sloping areas on the place, but mostly flat ground.
Thanks again!
Doc
   / Front End Loader on a 2WD Tractor? #8
I use a FEL on a JD 5103 with PS 2wd in Ga.with no Problems at all. On a small compact you will need ballast if it doesn't have PS or 4wd. you won't be able to hardly turn the wheel without moveing and the weight in the bucket you will loose your Drive Traction without any counter weight. If you are on alot of a Grade or Hills 4wd is almost a must. IMO.
Carey
   / Front End Loader on a 2WD Tractor? #9
If resale value is at all important to you, then get 4WD.
   / Front End Loader on a 2WD Tractor? #10
My old 4010 2wd
   / Front End Loader on a 2WD Tractor? #12
Ive ran 2wd tractors with FEL for years and never had any prob. Even most of the backhoes you see are still 2wd.
   / Front End Loader on a 2WD Tractor? #13
I am old to remember that thru the forties, fifties, sixties,seventies and eighties, you never seen a 4 WD tractor and we made it just fine. I farm over 300 acres with cattle, hay,corn,tobacco, strawberries,gardens, foodplots,landscaping and never had a need for one. Ken Sweet
   / Front End Loader on a 2WD Tractor? #14
Anyone that doubts the capabilities of a 2wd vs 4 wd with a loader only needs to try a 4wd, and dig in pile of dirt or stone with the tractor first in 2wd, then switch to 4wd. HUGE difference. Also as noted get a really full bucket and start down a wet grassy slope in 2wd, even with weight, then try it in 4wd. You will be a believer.
By the way I never missed 4wd in a tractor or pickup - UNTIL - I owned one. Every purchase since has been 4wd.
   / Front End Loader on a 2WD Tractor? #15
Growing up on a ranch as a kid we used a OLD John Deere G (johnny popper) with a DUAL loader and grapple for large round bales. The rear tires were loaded w calcium. Lot of work to move 1200# bales w/ no ps and a hand clutch instead of a foot clucth. Pick bale up and drive to trailer. If not in right spot, put bale down to lift up front end. Lift up bale, move tractor to right spot. Take tractor out of gear. Push in clutch to engage pto pump( yes I said push in, the clutch would pop in once pushed forward enough) let go of bale and start procedure over again. The fun times were when you would go down a slight incline and the tractor would move faster than the wheels would spin. Then you would white knuckle the steering wheel with one hand and the same to the seat rail ( oh what fun to clean out your shorts later).:laughing: The other fun would be when you were coming to a place where you needed to stop and you could not pop the clutch out. Then you would pull on the clutch handle as hard as you could and stand on the brakes and hope one would work.:shocked:
   / Front End Loader on a 2WD Tractor? #16
My experience is like Storm56. I grew up farming with 2WD pickups and 2WD tractors. I bought my first 4WD pickup in 03 and will never own another 2WD. My father in law bought a new MF 375 2WD in 85 just before he retired. After two months of getting stuck and poor performance especially in the hills, he traded it in on a 4WD model that we still have.
Apparently some like them, but I won't buy one with FEL.
   / Front End Loader on a 2WD Tractor? #17
Ballast, Ballast, Ballast. weight on the rear equal to weight on the front and 2 wheel drive will be all you will ever need. 4x4 never got me unstuck, only got me further before I got stuck, incedently when I get the 4x4 tractor stuck the 2 wheel drive always pulls the 4x4 out, at least it always has. That being said 4x4 with power steering is awful NICE (not nessesary) if you are doing a lot of loader work.
Just my 2 cents, good luck
   / Front End Loader on a 2WD Tractor? #18
Tractors 4WD, Trucks 4WD, ATVs 4WD. We have so many hills in WV it would be very difficult to manage without it. My former tractor had field chains on that never came off and it did not have a FEL. I would not buy another without 4WD. If it were flat and dry I may consider it but I am spoiled by what 4WD allows you to do.
   / Front End Loader on a 2WD Tractor? #19
I have sold new and used 4 WD tractors for many years. I know the advantages. Biggest disadvantage that no one ever mentions is: after you get 2000-3000 hrs on one and the maintenance issues start to be a common occurrence. Lots of people will be digging deep into their pocket book on a regular basis just to keep one in the field. If you just play with one on weekends, you will never have any problems. Ken Sweet
   / Front End Loader on a 2WD Tractor? #20
Another vote for 2wd
I never got my truck stuck untill i bought 4wd. Im from the Buffalo NY area if that means anything.
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59905)
2020 INTERNATIONAL...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2010 Volkswagen Routan Van (A59231)
2010 Volkswagen...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
