Cutting old fuel oil tank
   / Cutting old fuel oil tank #1
s78wingrider
Gold Member
Hardy Co. WV
Mahindra 3215 gear
I want to cut end out of old 275 gallon heating oil tank and can't afford torch. I have plenty of electric hand tools and blades, but don't know if that would be a waste of time or not? Would appreciate any suggestions. Thank you Aaron
   / Cutting old fuel oil tank #2
No direct experience with oil tanks, but a reciprocating saw with a good blade (or blades) should do the trick. I like the Milwaukee Torch blades -- they seem to stay sharper longer than the other blades I have tried.
Steve
   / Cutting old fuel oil tank #3
Reciprocal saw will work well... also can use metal cutting disks in an angle grinder.
Thanks! Been thinking of taking that approach. I have what I think are some good saw saw blades, guess I will find out! I also have small angle grinder I need to get blades for and may try old B&D skill saw I only use for cutting metal. Thanks again, Aaron
   / Cutting old fuel oil tank #5
I've used a reciprocal saw on an oil tank, worked very well. As a precaution, I filled the tank with water first! ~~ grnspot110
   / Cutting old fuel oil tank #6
Yes, NO SPARKS.
   / Cutting old fuel oil tank #7
assuming it was used as an oil (diesel, k1, #2, etc) and not a gasoline tank, you aren't going to have any issue with sparks. i've disposed of a few of them at scrap yards, and they always want them cut in half first. i've used a sawzall and it cuts through them easy and fast.
   / Cutting old fuel oil tank #8
Mine is in my crawl space. Anyone wanna come remove it?:laughing:
   / Cutting old fuel oil tank #9
I'd be a little worried about sparks myself,[course maybe cause I've been on fire a few times],you could run water in it,,use a angle grinder,,they sell different thicknesses of disks,,you want a thinner one,maybe not real thin cutting disk but maybe 1/8th thick one,,might need 4-5,,,welding supply places sell them.
2002 LULL 644B-42 TELESCOPIC FORKLIFT (A51246)
2002 LULL 644B-42...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
