Cutting old fuel oil tank
   / Cutting old fuel oil tank #1
s78wingrider
Gold Member
Hardy Co. WV
Mahindra 3215 gear
I want to cut end out of old 275 gallon heating oil tank and can't afford torch. I have plenty of electric hand tools and blades, but don't know if that would be a waste of time or not? Would appreciate any suggestions. Thank you Aaron
   / Cutting old fuel oil tank #2
No direct experience with oil tanks, but a reciprocating saw with a good blade (or blades) should do the trick. I like the Milwaukee Torch blades -- they seem to stay sharper longer than the other blades I have tried.
Steve
   / Cutting old fuel oil tank #3
Reciprocal saw will work well... also can use metal cutting disks in an angle grinder.
Thanks! Been thinking of taking that approach. I have what I think are some good saw saw blades, guess I will find out! I also have small angle grinder I need to get blades for and may try old B&D skill saw I only use for cutting metal. Thanks again, Aaron
   / Cutting old fuel oil tank #5
I've used a reciprocal saw on an oil tank, worked very well. As a precaution, I filled the tank with water first! ~~ grnspot110
   / Cutting old fuel oil tank #6
Yes, NO SPARKS.
   / Cutting old fuel oil tank #7
assuming it was used as an oil (diesel, k1, #2, etc) and not a gasoline tank, you aren't going to have any issue with sparks. i've disposed of a few of them at scrap yards, and they always want them cut in half first. i've used a sawzall and it cuts through them easy and fast.
   / Cutting old fuel oil tank #8
Mine is in my crawl space. Anyone wanna come remove it?:laughing:
   / Cutting old fuel oil tank #9
I'd be a little worried about sparks myself,[course maybe cause I've been on fire a few times],you could run water in it,,use a angle grinder,,they sell different thicknesses of disks,,you want a thinner one,maybe not real thin cutting disk but maybe 1/8th thick one,,might need 4-5,,,welding supply places sell them.
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2019 Kubota M6-111 (A50123)
2019 Kubota M6-111...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
