Just got my 2320 delivered today (pics)
   / Just got my 2320 delivered today (pics) #21
I keep telling my wife that im working outside but the big smile I have on my face is making a liar out of me..:D
mcgill,
We're all liars!
   / Just got my 2320 delivered today (pics) #23
You do know that the Imatch has non-standard lower hooks. Every thing that you get with it, including JD accessories, will need adapter bushings.
And the JD forks are not the best buy for this machine.
yep...if I remember right doesn't the iMatch come with one set of bushings for an implement so it can hook right up to the rear cutter? ...
even if I have to buy the bushings its soooo worth it for the cutter and for when I buy the box blade thats on my list ...:thumbsup:....as for buying forks , dont think I'll be getting any ..I really don't see a use for them with the kind of work I need done around the house....:)
   / Just got my 2320 delivered today (pics) #25
   / Just got my 2320 delivered today (pics) #26
I have to disagree. I have the Imatch and the JD dealer had to put bushings on my JD rake, JD trailer hitch adapter and JD ballast box in order to get them to work with the imatch.
Don't believe everything that you read on the web.
picked up the iMatch the other day and it had the bushings zip tied to the upper pin hole....got it home and hooked it up ...all I can say is its money well spent....even if I have to buy bushings for every implement I get its worth it not having to man handle everything that I need hooked up...:thumbsup:...
   / Just got my 2320 delivered today (pics) #28
Where you replying to me?:confused2:
The specs are the specs, you can search it for yourself-I don't need to.
ASAE Standard S278.6, Attachment of Implements to Agricultural Wheel Tractors Equipped with Quick-Attaching Coupler
   / Just got my 2320 delivered today (pics) #29
You got it my friend! TSC sells the bushings as well as this place online: http://agsupplyonline.com/.sc/ms/dd...ter Kit/34690/QUICK HITCH ADAPTER KIT CAT 1-3
   / Just got my 2320 delivered today (pics) #30
Too bad you guys don't do a little machining (I know you do Kenny). I buy DOM (drawn over mandrel) 1.5" OD and 750" ID trim it up a bit, takes about ten minutes, and I have all the bushings I need. I just saved more than twice the price of the BB to Imatch bushing on a 2' length of DOM that will make bushing for everything I own plus!
Rob
International Acid Tanker Truck (A52377)
International Acid...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
