Removing Broken Front Weight Bolts
   / Removing Broken Front Weight Bolts #1
CharlieTR
Gold Member
NE TX
Long LongTrac
I bought a third party grill with bumper/weight rack. Bolted it to cast iron frame of tractor and added the front weights. Turns out I added too much weight, and with a little help from running headlong into hiden ditches the four heavy fine threaded grade 8 bolts broke off. That was a couple of years ago. Now I want to remove those broken bolts and add the grill again. I installed the bolts with thead lock, I think the red heavy duty strengh that needs a tourch to remove it. I never worked with cast metal before and because that part is the main tractor casting, I am a little concerned about damaging the tractor. I there anything I need to worry about when adding heat to that case iron? I know not to quench it (with water).
Thanks,
Charlie
   / Removing Broken Front Weight Bolts #2
Heating cast iron is no problem...then try left-hand drill bits and hopefully the broken part will turn out with the friction of drilling.
   / Removing Broken Front Weight Bolts #3
If you have a welding machine, you might try welding a nut on top of the broken bolt. The heat from welding the nut on should be enough to melt the loctite and also give you a good hold on the bolt. I have found this works pretty well with most bolts, especially hardened bolts that are a PIA to drill. You just have to make sure that you only weld to the bolt and not the tractor frame. Try using a slightly smaller diameter nut that the OD of the bolt.
   / Removing Broken Front Weight Bolts #4
Good advise, but welding a flat washer to the broken stud and then welding a nut to the washer works better for me.
   / Removing Broken Front Weight Bolts #6
suitacse weight saga begins;
Thanks,
Charlie
If you use a welder be sure to disconnect the alternator wiring and the battery leads (and use safety goggles when unhooking and rehooking the battery and alternator please:thumbsup:
leonz
Forklift (A59228)
Forklift (A59228)
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
2016 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2016 VOLVO VNM...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE SLEEPER (A59575)
2007 FREIGHTLINER...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
