Can I test the amps from my alternator like this?
   / Can I test the amps from my alternator like this? #131
um.. not really... as far back as post 21, and many times thereafter people mentioned checking for bad wires / bad connections.
in post 120 I specificvally mentioned bad wire connectors, crimp connectors and bad connections hidden or otherwise..
soundguy
Sorry Chris, I missed that, my bad.
Steve
   / Can I test the amps from my alternator like this? #132
just making the point that it was not specifically a failure in diagnostics by all involved.. it was just a dern hard issue to pin down.... if it is indeed pined down even now..
soundguy
   / Can I test the amps from my alternator like this? #133
soundguy
You are right, soundguy. Back in the other thread when the original VR burned up and was being replaced. Egon, CharlieS, me, you, and zzvyb6, all suggested a close examination of the wiring. This all proves that it's one thing to say it and quite another to do it. Smitty was at his wits end with this problem and he thought he was doing everything right. Considering his lack of experience with electrical troubleshooting, I think he did a good job, especially with 10 or 15 of us giving him mixed directions.;):rolleyes:
Smitty, you found the problem and now things are gonna get better. Good job! Don't go 2nd guessing yourself. We are all happy for you.:thumbsup:
   / Can I test the amps from my alternator like this? #134
for sure.. especially for someone who is not electrically inclined.. diving head first into a charge circuit and the associated wiring must be a nighmare. the fact that it could have been umpteen dozen different things didn't help either. I'm just glad he finally found something that really looks like it could be the source of the issue.
soundguy
You knew this thread wouldn't die!!!
I finally got out to the garage and ran the tractor and took some more readings. I ran it for about 5 minutes and it was putting out 14.5 VDC at the battery. However, the VR and the wires got real hot again.
You have mentioned that it might be the starter solenoid but I checked that and it seems fine. If it was the glow plug, wouldn't the dummy light not be functioning correctly which it now is.
I AM BACK!!!!!
   / Can I test the amps from my alternator like this? #136
I AM BACK!!!!!
The bug is back again, I would look at that bad connector again. Does that connector or any other connectors get hot?
Once you get the engine running, carefully remove the wire to the starter solenoid and the glow plugs. Is the VR and wires still hot?
will do
another thing: does the fact that the tractor won't run when I disconnect the postive battery cable (after starting it) show that there is still a problem? what problem could that be a symptom of???
   / Can I test the amps from my alternator like this? #138
don't have a big capacitor do you? something large inthe 4-8000uf range?
soundguy
   / Can I test the amps from my alternator like this? #139
well, like i said before, i have given this a good try but I am ready to admit defeat. I don't know nor have the tools for the tests that you are recommending.
so here is my plan: I want to mow a few times before I send the tractor to the shop. I am planning on disconnecting the alternator so it doesn't continue to heat up the VR. I will also disconnect all light bulbs that draw current when I am mowing (i.e. the PTO light). Hopefully I will be able to mow my entire 5 acres before the tractor dies. Then I will recharge battery using a battery charger.
Does this sound like an okay thing to do until I get it fixed?
Take your alternator out and take it to a shop for testing. They will find out exactly what is wrong (alt or reg.) in 5 minutes then can generally fix it the same day - usually costs ~$50. Done.
JayC
   / Can I test the amps from my alternator like this? #140
remember.. this 'alt' is a permanent field type dynamo with external rectifier and regulator pack.. not a regular alternator with field control and heavy rectifiers and a diode trio.
soundguy
2015 Ram 3500 Crew Cab Truck (A52384)
2015 Ram 3500 Crew...
2012 Manitex 50110SHL 50-Ton Boom Crane Truck (A53117)
2012 Manitex...
MISC BASKET OF HYDRAULIC PARTS (A53843)
MISC BASKET OF...
Scag Mower (A50324)
Scag Mower (A50324)
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
