Conoco Tractor Hydraulic Fluid
   / Conoco Tractor Hydraulic Fluid #21
post what you find.
soundguy
   / Conoco Tractor Hydraulic Fluid #23
sounds like a very 'greene' article to me.. perhaps enticing greene machine owners to buy branded oil...
soundguy
   / Conoco Tractor Hydraulic Fluid #24
soundguy
Yeah, gotta factor that in, but still. Enough concern expressed to be careful, I think. There are blenders and then there are blenders, I should think.
   / Conoco Tractor Hydraulic Fluid #25
If I bought an oil that ONLY met the 303 or 20a spec.. I might be concerned. but you see 20 other specs listed on most of the utf sold today.. some of them on the much newer end...
soundguy
   / Conoco Tractor Hydraulic Fluid #26
Update:
Got the report back from the lab. There was no contamination and everything was pretty much in order.Only areas above tolerances were high silicon and lead.
So spank me as I was falsely blaming the fluid manufacturer.
I do notice hydraulic pump singing when cold and surmise it prob the new filter may have some flow restriction.
I will in the future change fluid and filter more often.
Tom
91013 (A48082)
91013 (A48082)
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A55218)
2022 NEW HOLLAND...
