Kubota Newbie! L245DT/1200 FEL
   / Kubota Newbie! L245DT/1200 FEL #11
You are right. It ain't got any more curl left.
Is there a reason they build them that way?
   / Kubota Newbie! L245DT/1200 FEL #13
This does not appear to me to be the original bucket designed to go with those arms. My arms are similar but I have at least 2x as much tip back as you do. I am not home right now and neither is my tractor, I will see if I have any suitable pictures to post to display what I mean.
Is your loader a Kubota 1200 or an aftermarket loader?
   / Kubota Newbie! L245DT/1200 FEL #15
Dook:
It is a Kubota LA651. My tractor is a little larger than yours, but I believe our FEL's are of very similar design. If I could figure out how to attach a picture from my I-phone to this message, I can send you a pic, but the bucket is halfway unfurled, so it is difficult to compare to your pic.
   / Kubota Newbie! L245DT/1200 FEL #16
Dook:
Finally, here a a pic for comaprison.
   / Kubota Newbie! L245DT/1200 FEL #17
I also have a 1200 loader and that is as far as the bucket curls.
also i really couldn't see the pictures of the loader controls but if they are like mine it does have a float position. i had to replace an o ring in mine and found that the ball bearing that controls the float was missing. i found one that would fit and it returned it to having a float position.
Dook:
Thanks for posting the pic, cycle gator. Your bucket looks like an "L" profile, which is a newer design and better, IMO.
I got the float working. I had thought the float was in the up position of boom control for some reason and found it by accident....duh.
If that's as far as the bucket curls on yours, I guess that's the way they designed them back then. I don't like it.
I might even consider re-positioning the lower pin on the bucket so it can curl more....need to figure out how much dump angle I'll lose.
I'm having a bit of buyers remorse. :(
1720 (A54756)
1720 (A54756)
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
