Ferguson Two Bottom Plow
   / Ferguson Two Bottom Plow #1
nebraskasparks
Gold Member
Northern Illiniois
2010 Kubota L5740 HST and JD X734
Anybody have a web site where I can research and place a value on a Ferguson Two Bottom Plow? Excellent shape and still plow with it.
Plow has brass tag with model (14a) and number (5387) on it.
   / Ferguson Two Bottom Plow #2
I think you may be on the site where you can find a value. Ken Sweet will be along by tomorrow morning and give you an opinion for your part of the world (I think). Put a tape from the center of one beam to the other.....my guess is that its 2x14" bottoms.
In the meantime.....I say a nice two bottom Ferguson plow with counters, a rolling landslide, and no need for major repair will sell for $350 to $550....maybe a bit more ...depending on how bad you want one. ;)
One thing.....I'm not certain that parts interchange with a Dearborn or Ford plow...which could be a factor down the road. ?? (For occasional or garden use....it would likely last a loong time.) Seems you can find parts for the Fords and many Dearborns.
I think the value of these good old plows keeps climbing a bit as there become fewer good ones available to buy. They are more desirable to own/use than a new plow....IMO. I can remember having an assortment of plows like that shown that we offered at $50 to $100....but that was 40 years ago. (grin)
   / Ferguson Two Bottom Plow #3
dearborn of the same style go for 300$ pretty commonly.
soundguy
   / Ferguson Two Bottom Plow #4
soundguy
I have the exact same Fergeson-Sherman plow. I'm not expert but have heard it is a little more valuable than the traditional Dearborn, Ford or other Fergeson plows because of:
-main beams were more intricate with molded attachment points for the coulter wheels right in them rather than using a couple of little shaped pieces that clamp the wheel attaching arm.
-the top support is also cast and of a shape different than the others.
   / Ferguson Two Bottom Plow #5
From the picture, It appears to be a 2 piece setup on the moldboard with point/share. If this is the case, the plow is fine until you break something. Parts are not available unless you can get a blacksmith to make parts. If I am wrong and it is a 3 piece setup with moldboard/point/share and the shin. Parts are inexpensive and easy to find. Ken Sweet
   / Ferguson Two Bottom Plow #6
This is a 3 piece setup on a plow. You can see in the picture the outline of all 3 parts. We ask $450 for this plow. Ken Sweet
   / Ferguson Two Bottom Plow #7
An additional option is to replace the frog, preferably with one with a moldboard/point/share in good shape already attached. Maybe parts from a plow with bent beam(s) might be available.
   / Ferguson Two Bottom Plow #9
Ken, What size is this one? (12, 14, 16, other?)
This one is 14 inch Ford. We have a 14 inch Trip beam John Deere that will be coming out of the shop this week. It has coulters on it and is really super nice. We have a lot of 2-12 plows with no coulters solid beam starting at $375 + modest shipping.(some may need a coat of paint but are not sprung.) In addition, we have some 2-12 trip beam plows in the $450 range with no coulters. Ken Sweet
   / Ferguson Two Bottom Plow #10
I have one very much like that one that I gave $250 for about 24 years ago. I had no idea it was appreciating. I still use it, so it's market value is not of much concern to me.
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
Forklift (A56857)
Forklift (A56857)
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
(APPROX. 20) 4' X...
