Weight Distributing Hitch On Dump or Equipment Trailer?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #31
What would you do if the trailer had front mounted tool box with the pump/controls in it? Would you still be able to mount the WD hitch?
If you really wanted to you could get a set of these bolt-on hangers and use a WD hitch on a trailer with the tool box that gets in the way of the traditional hangers which go over the frame rails.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #32
You know, I wish I'd known of those bolt on hangers when we got the Bri-Mar years ago. I ended up modifying the pump box to accommodate the traditional hangers.
techwrtr2,
If you could post a picture of it hooked up to your trailer, I'd really appreciate it!!! :thumbsup:
   / Weight Distributing Hitch On Dump or Equipment Trailer? #34
The bolt on's solve some mounting problems but take a lot longer to hook up unless you have an electric jack..you have to raise the trailer tongue, while attached to the truck, up in the air a good bit to attach the chains, otherwise you can't get the needed tension.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #35
True, they don't have that pivot motion that the traditional brackets do. I wonder why...
   / Weight Distributing Hitch On Dump or Equipment Trailer? #36
Thanks for the information. A weld on bracket version makes sense and I assume it goes on the side of the tongue frame since it cannot go over it. I will contact my local dealer where I bought the trailer and see if I can order a pair to go with my weight distribution unit. If you know anywhere that I can buy these online that would be helpful as well. Attached is a picture of my trailer.
Draw Tite and Reese make them. I just bought a Draw Tite set from etrailer.com, but it now comes up as a Reese set. Chain Hangers for Reese Weight Distribution Systems - Bolt On Reese Accessories and Parts RP58305
They're about $55 bucks. I have a Load Trail 14k equipment trailer that has a wide piece of angle iron in the way of the reuglar chain hangers, so I had to buy this set which can either be welded or bolted on.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #37
Draw Tite and Reese make them. I just bought a Draw Tite set from etrailer.com, but it now comes up as a Reese set. .
Draw Tite and Reese are owned by the same company, I've noticed that some of their products are now identical.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #38
Yep, been that way since about 2004??? There is another company in the mix with them but the name slips my mind right now.
Chris
   / Weight Distributing Hitch On Dump or Equipment Trailer? #39
I'm a huge believer in Weight Distributing hitches. I pulled a 30 foot camper with my 1/2 ton truck for a few years. I couldn't have done it without the WD Hitch.
Now I'm debating putting a WD hitch on my tilt trailer. I suppose I'll have to unhook the torsion bars each time I load or unload.
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A55973)
2015 Peterbilt 348...
2011 GMC Yukon XL Denali SUV (A56859)
2011 GMC Yukon XL...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
