Weight Distributing Hitch On Dump or Equipment Trailer?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #31
What would you do if the trailer had front mounted tool box with the pump/controls in it? Would you still be able to mount the WD hitch?
If you really wanted to you could get a set of these bolt-on hangers and use a WD hitch on a trailer with the tool box that gets in the way of the traditional hangers which go over the frame rails.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #32
You know, I wish I'd known of those bolt on hangers when we got the Bri-Mar years ago. I ended up modifying the pump box to accommodate the traditional hangers.
techwrtr2,
If you could post a picture of it hooked up to your trailer, I'd really appreciate it!!! :thumbsup:
   / Weight Distributing Hitch On Dump or Equipment Trailer? #34
The bolt on's solve some mounting problems but take a lot longer to hook up unless you have an electric jack..you have to raise the trailer tongue, while attached to the truck, up in the air a good bit to attach the chains, otherwise you can't get the needed tension.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #35
True, they don't have that pivot motion that the traditional brackets do. I wonder why...
   / Weight Distributing Hitch On Dump or Equipment Trailer? #36
Thanks for the information. A weld on bracket version makes sense and I assume it goes on the side of the tongue frame since it cannot go over it. I will contact my local dealer where I bought the trailer and see if I can order a pair to go with my weight distribution unit. If you know anywhere that I can buy these online that would be helpful as well. Attached is a picture of my trailer.
Draw Tite and Reese make them. I just bought a Draw Tite set from etrailer.com, but it now comes up as a Reese set. Chain Hangers for Reese Weight Distribution Systems - Bolt On Reese Accessories and Parts RP58305
They're about $55 bucks. I have a Load Trail 14k equipment trailer that has a wide piece of angle iron in the way of the reuglar chain hangers, so I had to buy this set which can either be welded or bolted on.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #37
Draw Tite and Reese make them. I just bought a Draw Tite set from etrailer.com, but it now comes up as a Reese set. .
Draw Tite and Reese are owned by the same company, I've noticed that some of their products are now identical.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #38
Yep, been that way since about 2004??? There is another company in the mix with them but the name slips my mind right now.
Chris
   / Weight Distributing Hitch On Dump or Equipment Trailer? #39
I'm a huge believer in Weight Distributing hitches. I pulled a 30 foot camper with my 1/2 ton truck for a few years. I couldn't have done it without the WD Hitch.
Now I'm debating putting a WD hitch on my tilt trailer. I suppose I'll have to unhook the torsion bars each time I load or unload.
(2) SHOP VACS ON PALLET (A58374)
(2) SHOP VACS ON...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
