Warranty void by adding hooks on FEL?
   / Warranty void by adding hooks on FEL? #1
yooper1
U. P. of Michigan
New Holland T1510
I am hoping to put a couple of hooks on my FEL. I was going to weld on 2 of the 3/8 grab hooks.
I searched and read many posts about positioning, sizing, beefing up the top of the bucket, etc.
I saw a couple of posts suggesting that they voided their warranty by adding hooks to the FEL. :eek:
I know I could call my dealer and get an actual answer, but wanted actual real world user input. Also I am afraid of their possible answer.
Has anyone actually voided their warranty when they did this?
Also, was it just the loader warranty or the whole unit warranty.
I would hate to void my 2 year warranty just by wanting 2 darn bucket hooks :mur:
None of the posts / threads I read had any actual concrete wording that a warranty was voided.
Maybe there is a somewhat decent way to lift things without the welded on hooks that a member has / is using. Maybe a towstrap around the bucket?
   / Warranty void by adding hooks on FEL? #2
I hope it doesn't yooper. The dealer welded my hooks to the bucket while it was still under warranty.:D:D
   / Warranty void by adding hooks on FEL? #3
What impdaddy said ....
   / Warranty void by adding hooks on FEL? #4
I have never read of a warranty being voided by welding hooks on the bucket. Now, I did have the dealers weld hooks on both my 670 and 790...the 4400 had hooks when I bought it.
If your bucket is Quick Attach, drop it off the loader before welding. There is a possibility of damaging the alternator and (on newer tractors with computers) other electronic items if the welder is not grounded properly.
Dropping the bucket off the loader eliminates that possibility.
   / Warranty void by adding hooks on FEL? #5
My dealer welded hooks to my FEL as well as welding a trailer ball to my box blade before I took delivery of my new tractor.
ooh, not quick attach, but supposed to be somewhat easy to un-bolt
Also I would imagine that if a warranty were to be voided there must be tens of thousands of tractors out there with the hooks and voided warranties
So...maybe I should just ask my dealer and get it over with
   / Warranty void by adding hooks on FEL? #8
I have never heard of bucket hooks voiding a warranty, but that doesn't mean it has not happened. As far as lifting w/o hooks, I don't recommend it. I reinforced the top edge of the bucket with 3/8" X 2" angle and used 3/8" plate to reinforce the bucket directly below where the hook is welded on. The hooks have become my most used attachment and I have not had any problems or distortion of the bucket.
   / Warranty void by adding hooks on FEL? #9
I personally have welded on many hooks to loader buckets while working at the dealer, Kubota and New Holland. It does not void the warranty, but I don't expect you to come back wanting a new bucket when you bend it picking up something too heavy or the wrong way, either. I'm sure there have been cases where this has happened, so I can see how a dealers policy could become not to weld them on, or to tell you the warranty is void.
Brian
   / Warranty void by adding hooks on FEL? #10
Hopefully I haven't voided mine......but they sure work great.......:p
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
2007 CAT 904B (A47384)
2008 FREIGHTLINER B2 BUS CHASSIS (A51222)
2008 FREIGHTLINER...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
