Converting John Deere 7 backhoe to 3 point
/ Converting John Deere 7 backhoe to 3 point #1
Greygoose
TYM 394
Hi All-
Have a 254II Lenar 4X4 and just got a good deal on a John Deere 7 backhoe that needs a little work and was wondering if anyone ever converted one of these to a 3 point setup.It looks like all I would have to do is cut off the long frame mount legs and drill them for pins to hook up to the lower lifting arms of my 3 point,then just use the correct length top link? I checked the weight and the 7 is actually lighter (800lbs?) than other 3 point backhoe attachments,so I think I should be ok there.
Mike
/ Converting John Deere 7 backhoe to 3 point #2
Why not make the subframe fit your machine? You will have a MUCH stronger setup and you won't risk breaking your tractor. It's not just the weight of the backhoe, it's the forces it imposes when your digging that will cause problems.
First off I don't have the subframe,only the 2 small pieces for the very front of the legs came with it.Also,I am only going to be doing very light duty work maybe once a month with it.And unless I can figure out the hydraulics,I may sell it as is.Is there supposed to be a return line on these?I only have one quick connect,but right above that fitting on the valve body,there is a line missing-just an empty threaded hole that leaks some oil when the unit is moved.Thanks again,
Mike
/ Converting John Deere 7 backhoe to 3 point #4
Mike
You need two lines to run the backhoe, one is the feed and the other is the return-to-tank line. Backhoes are usually powered by what is called the "Power Beyond" lines on the tractor. I assume you have a FEL on your tractor? If so, then how many hoses are connected to the valve?
Thanks Kenny-
I have one high pressure feed line at the back of my tractor with the quick connect fitting to hook into the in line.I have no return fitting on the tractor though.I did find on the backhoe valve body the return line fitting right above the in fitting (it says "out").It is missing the line along with a couple of others that were robbed off the backhoe by the previous owner.My front end loader has a total of 7 fitting holes-5 are used for the loader hooked up and 2 just have threaded plugs in them.Thanks again very much,
Mike
/ Converting John Deere 7 backhoe to 3 point #6
OK, 5 makes no sense...You have 4 from the work ports to the bucket cylinders, then you have 1 FEED connected to the IN port from the pump. Then you will have 1 or 2 more...for a total of 6 or 7.
Can you post pictures of your machine, with close ups of the valve?
Your are right Ken-sorry.There are a total of 6 lines running into the front end loader valve.
Mike
/ Converting John Deere 7 backhoe to 3 point #8
OK, so since you have only 6 hoses, you do NOT have the common "Power Beyond" setup in use.
Now bear with me, I have questions...
Are any of the ports labeled on that valve? If so, is there one marked PB or BYD?
Who in the maker of it?
What is the GPM and PSI rating for your machine?
/ Converting John Deere 7 backhoe to 3 point #9
Thanks Kenny-
How does this line get activated? You can't have a high pressure line and no return...the PRV (pressure relief valve) will always be active and the fluid would overheat, or the pump would grenade itself. Post more pictures.
On the rear of the tractor is a quick connect fitting.If you can look at this manual on page 20,maybe you can make sense of it for me.I did find the optional return tapped hole.Thanks again.
http://www.mahindrafrance.com/mahindra254.pdf
I also just noticed that according to section 16 and 17 (the hydraulic section
in the manual) in the lift arms lowered position,I may not have hydraulic pressure in the auxillary quick connect.So I may need to install a seperate line (power beyond) to feed the high pressure in on the backoe.
/ Converting John Deere 7 backhoe to 3 point #12
Boy I would love to be able to find a used JD backhoe. They are scare as hens teeth up here. Congrats on the find
/ Converting John Deere 7 backhoe to 3 point #13
Hi Mike,
You need two hoses from the BH. The input/pressure for the BH is from the mounted QD, and that gets it's pressure from the 3ph lever when in the top 15%, and that is where you have constant fluid flow . The return hose from the BH has to go to tank/reservoir, and there should be a fitting on the tractor for that. When using the BH, the lift arms should be locked in the position you want.
I never did see the hyd pump GPM rating. Small BH's, do not need a lot of hyd flow.
/ Converting John Deere 7 backhoe to 3 point #14
Mike
The Control Knob will lock the 3ph arms wherever you want. Then use the top 15 % of the Control lever for constant hyd flow..
You should brace the BH somehow. Did you say the stabilizer legs are on the machine?
Yes,J-J,the legs are still on it but I only have the small mounts for the front of them,and to utilize those,it would be a MAJOR subframe build as there is nothing even close to them under the the tractor where the end mounting points of those legs are.I was going to cut off those long legs and just use the lifting bars and top link-just like any other 3-point attachment.Now I am thinking like you-I probably should put some of the weight on the drawbar mount or rear axles or something?? I have a tiller that weighs around 400-500 pounds I would guess,but this think is maybe 800,and like Kennyd said earlier in this post,it will produce allot more force on the tractor.If I break out the rear case by the top link or even break the tractor in half,the whole rig is pretty much scrap metal.
Mike
/ Converting John Deere 7 backhoe to 3 point #16
I just read it...it seems that QD at the rear can only be used with a SA (single acting) cylinder, like on a dump trailer that's powered UP but gravity DOWN. You will need to plumb in a PB circuit IMHO.
DANG! So I am back to square one.Any suggestions on doing the plumbing?
/ Converting John Deere 7 backhoe to 3 point #18
The manual says constant pumping, then that is a constant flow, and there is no reason that it would not power the BH, if you have a place to return the flow, if the GPM's and pressure are available. Sure it could be used for dump, and if you held it there, it would relieve. Why would it say constant pumping. If someone put a flow meter and gage on it they would probably have flow and pressure if a load is in place.
The manual says it can be used for implements that require hydraulics, including dump cyl.
Could I damage anything if I just hook it up and try it?I was going to just stick the return line in a 5 gallon bucket to flush the backhoe system since it has sat for awhile with some of the lines disconnected.I will of course replentish the oil as needed in the tractors system.:thumbsup:
Mike
/ Converting John Deere 7 backhoe to 3 point #20
Mike
Yes, you can try it with no ill-effects. Still need answers to above questions?
3015 (A56857)
3015 (A56857)
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
11' CONTAINER (A60432)
(39) FLOOR TRUSSES (A60432)
(39) FLOOR TRUSSES...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
