OP
rsmith02184
- Joined
- Nov 9, 2005
- Messages
- 114
- Tractor
- JD 4100
okay.....my wife says she WHOLE HEARTEDLY agrees it is time to send it in!!!! It has beaten me for now!!!!
rsmith02184 said:okay.....my wife says she WHOLE HEARTEDLY agrees it is time to send it in!!!! It has beaten me for now!!!!
Any results yet?
You probably made a weak battery out of yourself and metal. ... A good voltmeter is extremely sensitive, requiring so little input to read that even open [non connected] leads will often cause it to dither a little. When you connected both leads - - one to the neg and one to the chassis you essentially shorted them together getting Zero since no current was being drawn. If thus connected, you had then put the meter on a more sensitive scale had turned the lights on you would have seen a voltage reading telling you the V loss from the neg terminal to the ground. If you were then able to double the load the meter reading would double and so on.also, help me out with this mystery: i had my neg. lead to the meter clamped on the negative battery terminal and when i touched my finger to the positive lead of my meter, it showed .5 DCV reading. It seemed to register this when my arms were touching the metal FEL. when i placed the positive lead of the meter directly to the metal, there was no reading.
what would cause this strange reading????
