best 3pt finish mower
   / best 3pt finish mower
and what is the warranty on them
   / best 3pt finish mower #23
1 yr manufacturers warranty against defects in material and workmanship and 3 yr on the gearbox. The anti scalp roller is not standard equipment on these machines, however, is available. Here are the specs. Ken Sweet
What's the typical adder for the anti scalp
   / best 3pt finish mower #25
Most of my customers are only using that roller if they are mowing a old pasture field that has been turned into a yard. The cost of the roller kit Is $100. Ken Sweet
   / best 3pt finish mower #26
Gotta throw another vote for the KK RFM72. Mine also is older 4 years and around 500 hours besides a new cheapo belt and baldes each year later I've replaced 1 spindle due to a pulley issue. It was cheaper to buy the whole assembly from TSC ($38) than just get a pulley.
We are rough on stuff and my FIL is getting up there with alzheimers. This summer I got home from work and saw him mowing some thick 2+ foot stuff with it. Did not last long - He BROKE the shear pin. I checked the mower and he had also filled the gear box to the top - bless his heart (what we say in the south when we mean dumb sob) and broke the tension spring!
Drained the box to the proper level,installed a grade 2 bolt - it was already past time for a new belt and blades so I had those on hand. Its been around 50 mowing hours since then (I mow around 12 acres with it, I mow ALOT) and everthing is still ok
To me best is more than a single attribute - initiall cost,local availabilty, reasonable replacement parts. Here in east texas woods could not offer a better solution on these 3 points.
Good luck!:)
2019 Ford Fusion Sedan (A51694)
2019 Ford Fusion...
2009 Tahoe 195 Boat (A53117)
2009 Tahoe 195...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
