Wood splitter on a 790?
   / Wood splitter on a 790? #1
grnspot110
Elite Member
MO
John Deere 1944- H, 1961 Cub Lo-Boy, 2016- JD 2025R, 2018- JD X580
I have a vertical hyd splitter I made to use on my JD 1958 - 520 using tractor hydraulics. I've sold the 520,so I need to re-make the splitter to use on my 790. Plan is to set it up to "free-stand" the splitter(maybe w/bracing) beside the tractor & hook the hyd. hoses to the "bucket" connections on the tractor.
I've used this set-up on the 520 for several years & though it's not fast, it works well for me. I work by myself, so speed is not a problem! This is not something I will use frequently, but comes in handy sometimes. I prefer to split by hand if it's not too hot.
Any suggestions? ~~ grnspot110
   / Wood splitter on a 790? #2
Seems to me that quite a few 790 owners have used a wood splitter on their tractors. I think most of 'em used the Power Beyond hydraulics to run the splitter. I think the 790 provides about 5 gpm or so.....what do you need to operate that cylinder efficiently?
I don't have the Power Beyond on mine. Anybody know what that would cost (approx.) installed? I'm thinking of being beside the tractor for easy access to the joy stick.
Not sure what the gpm's were on the 520, do know it had low pressure system. ~~ grnspot110
   / Wood splitter on a 790? #4
According to my manual, the 790 main pump can pump 5.6gpm at rated speed, and the power steering is 4.3gpm. Total flow is 9.9gpm, but that's not really a usable spec is it?? The two systems can't be combined, right??
   / Wood splitter on a 790? #5
I have a power beyond on my 2009 3005 (renumbered 790) - essentially two hydraulic hoses coming out the back with no valve. They couple together when not in use for an implement. Had them put on by the dealer for $250when I bought it last December . Use the hydraulics it to run my Rankin ~20 ton splitter. It may not be fast enough for some, but boy is it effective!! :thumbsup:See some of my other posts for pictures.
Mf
   / Wood splitter on a 790? #6
Correct, the steering pump cannot be counted here...5.6 is the number to use.
   / Wood splitter on a 790? #7
Mf
Yup, about $250. The PB is the best way to operate the logsplitter.
   / Wood splitter on a 790? #8
an elcheapo way if you have a fel is to use a set of those outlets
tie the stick back in the raise position but be sure you have a center open double action valve on the splitter
I've always used the control on the 520 by disconnecting the linkage from the hydraulic lever & flipping it over to a lever on the back of the tractor (in the closeup pic, the faded gray conduit w/white cap at center right). Thought I'd just set the 790 up so I can use the joystick & the bucket cylinder quick-connects. Might need to make an extension for the joystick. ~~ grnspot110
Next question! Is the "power beyond" a simple installation or should I have the dealer install? I do have "intermediate" mechanical skills. ~~ grnspot110
   / Wood splitter on a 790? #11
It is not that hard, and the instructions are pretty good...Go for it.
Had problems with the790 last week! Driving along a field edge when it "just died"! :( It would start & run about 3-4 seconds & die, checked fuel (OK), didn't see any problems. So I "hopped" it onto the trailer (2-3' at a time), & took it to the dealer for repair & since it has 444 hours, had them do 500 hour service while they had it.
Picked it up today, of all things, somehow a stick or something, had hit the fuel shut-off lever & turned it off! With the side panels on! They also found a "weeping" fuel line, replaced it.
I asked about the rear hydraulics kit, NLA. They could have "pieced" it on for me at over $1500!!!! :confused2: So I'm going to add a control valve to the splitter, available locally, & have hoses made to reach the bucket cylinder connectors. Just unplug the bucket cylinders, plug in the splitter & tie off the joy stick. ~~ grnspot110
   / Wood splitter on a 790? #13
So that is kit # BM18005 that is NLA? Hard to believe...anyway they turn up on eBay every now and then, or you can make up your own PB kit.
Got the splitter plumbed today, $23 from JD for the male couplers, $70 for two 3/8" x 8' hoses & $95 for a control valve, plus assorted pipe fittings. Don't have anything home right now to test it, but it works fine w/o load!
Just went to the bucket cylinder connections, won't be using the bucket & splitter at the same time anyway! Tarp strap the joystick to the fender & go to work! ~~ grnspot110
   / Wood splitter on a 790? #15
Looks good EXCEPT for that galvanized water pipe:eek: That stuff-especially the fittings are only rated for like 300 PSI.
Hasn't been that long ago some machinery companies used galvanized pipe & fittings for implements Glenco for one! ~~ grnspot110
404 (A52706)
404 (A52706)
2015 Chevrolet Impala Sedan (A59231)
2015 Chevrolet...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
2017 Case CX145D (A60462)
2017 Case CX145D...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
