Old Fuel Tank ... Restore it?
   / Old Fuel Tank ... Restore it? #11
I have cleaned a few out using a sears shop vac after I blow compressed air in with a wand extension. Banged it ariound a bit to loosen stuff up and vacumn out the best you can. I then put a little diesel in and slosh around and rinse out. If they had diesel in them I useally don't find all that much rust, just fine crap.
I always use a debris and water filter on my diesel fuel tank--two filters.
Sounds like you have a home heating oil tank which might be thinner steel so more likely to have some problem.
The pressurized air idea is brilliant.
   / Old Fuel Tank ... Restore it? #14
1*I always use a debris and water filter on my diesel fuel tank--two filters.
2*Sounds like you have a home heating oil tank which might be thinner steel so more likely to have some problem.
1*This filter filters both so no need for 2 filters.
2*All the tanks are the same because the fuels are the same .
   / Old Fuel Tank ... Restore it? #16
1--You are 100% correct, but with tens of thousands of $$ of my hard-earned equipment at stake, I feel better with an extra $20 of fillter.
2--On the tank, maybe modern home heating oil rectangular tanks are the same thickness these days, but I have seen many older ones that were noticably thinner than an outdoor diesel tank. Beats me, maybe some were indoor fuel tanks? .
Diesel fuel tanks out my way sell pretty cheap. $50 is common, $100 high and $30 cheap. Seems like sealing one is a lot to go through for an uncertain destiny?
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
