Old Fuel Tank ... Restore it?
   / Old Fuel Tank ... Restore it? #11
I have cleaned a few out using a sears shop vac after I blow compressed air in with a wand extension. Banged it ariound a bit to loosen stuff up and vacumn out the best you can. I then put a little diesel in and slosh around and rinse out. If they had diesel in them I useally don't find all that much rust, just fine crap.
I always use a debris and water filter on my diesel fuel tank--two filters.
Sounds like you have a home heating oil tank which might be thinner steel so more likely to have some problem.
The pressurized air idea is brilliant.
   / Old Fuel Tank ... Restore it? #14
1*I always use a debris and water filter on my diesel fuel tank--two filters.
2*Sounds like you have a home heating oil tank which might be thinner steel so more likely to have some problem.
1*This filter filters both so no need for 2 filters.
2*All the tanks are the same because the fuels are the same .
   / Old Fuel Tank ... Restore it? #16
1--You are 100% correct, but with tens of thousands of $$ of my hard-earned equipment at stake, I feel better with an extra $20 of fillter.
2--On the tank, maybe modern home heating oil rectangular tanks are the same thickness these days, but I have seen many older ones that were noticably thinner than an outdoor diesel tank. Beats me, maybe some were indoor fuel tanks? .
Diesel fuel tanks out my way sell pretty cheap. $50 is common, $100 high and $30 cheap. Seems like sealing one is a lot to go through for an uncertain destiny?
Toro Mower (A50324)
Toro Mower (A50324)
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
