Trying to install rear remotes on L4400
   / Trying to install rear remotes on L4400 #21
Interesting... that shows it being in series. That should work if the BH is open center as there will always be pressure from the outlet port. I guess I will have to check if my BH is open center... :confused2:
   / Trying to install rear remotes on L4400 #22
Does your backhoe have a make/model?
   / Trying to install rear remotes on L4400 #23
I could be wrong but I think you would have to connect the BH hoses together if you took it off of the tractor.
   / Trying to install rear remotes on L4400 #24
I have a L3400 with a backhoe. When you disconnect the backhoe you must connect the hoses together.
   / Trying to install rear remotes on L4400 #25
Likely the same for the L4400 then. Thats what it looked like to me but I am so expert in hydraulics. :thumbsup:
   / Trying to install rear remotes on L4400 #26
It is a Yanmar YBH-600. I have a manual but it shows as having it's own pump which it doesn't have.
I actually have a L3400, I just hi-jacked this old thread :ashamed:
   / Trying to install rear remotes on L4400 #27
Buying a pump would be cheaper then adding remotes... besides, I'm not too sure remotes will work with that backhoe. Most likely it has it's own oil tank in the frame and the valves are set to dump and pump oil from there... Not sure which pump to buy, ask that in hydraulics section... my guess it's going to run $500-ish????
   / Trying to install rear remotes on L4400 #28
Greetings!
I noted on a webpage that you might have operator and./or parts manuals for the Yanmar YBH-600 backhoe yes?
Interested
Thanks!
Ed
ebjorgensen@jorgie.net
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
2003 Club Car Utility Cart (A56859)
2003 Club Car...
1695 (A58375)
1695 (A58375)
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
Mini Excavator Rock Bucket (A55272)
Mini Excavator...
2162 (A58376)
2162 (A58376)
