Need to locate a loader cylinder
   / Need to locate a loader cylinder #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
I am working on a tractor for a guy and it has a loader on it that leaks down bad. I have taken the cylinder off and they are bent up and not well made. I would like to locate something to replace them with.
I can get the OEM cylinders but they are so poorly made I am wanting something better plus they are almost $300 each.
Here is what I need.
The cylinders on it now are 2" dia and 22" stroke. They have 3/4" pin holes on each end and 2" mounts on both the cylinder end and the piston end. The retracted length is 29.5" pinhole to pinhole centers and the extended length of 51.5" pinhole to pinhole centers.
Anyone have any idea where I can get something like that?
I did a search and found some at Surplus Center that would work but they are only 1.5" dia.
Thanks
Chris
   / Need to locate a loader cylinder #2
Thanks
Chris
Try Baileynet.com I got 27" by 1 3/4" for $116.00 so they may have what you are looking for.
BROCE BW260 SWEEPER (A60429)
BROCE BW260...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
