Chainsaw Bar Oil ??
   / Chainsaw Bar Oil ?? #51
my 390 cost me around $1300 with taxes/delivery/chains ... and I put the most expensive no name/store brand $8 gallon of bar oil I can find.
I'm burning about 5 gallons of gas a week in the saw, and about 2 1/2 gallons of oil when I am really ripping through it
   / Chainsaw Bar Oil ?? #52
The problem I found with regular oil on a chainsaw bar is it gets hot and runs off the bar. I use bar oil as it has some type of sticky adhesive quality that seems to keep it on the bar.
   / Chainsaw Bar Oil ?? #53
My gosh, is that canadial dollars or have they gone up that much. I really dont remember but after it was all said and done with an upgrade to a 20" bar i think i only paid a little under $600 for mine, that was 6 years ago though. I have MS 390.
   / Chainsaw Bar Oil ?? #54
sorry I should have been specific ... its a huskie 390 not a stihl =) 88cc not 56
   / Chainsaw Bar Oil ?? #55
ok that would make a lot more sense. I did not want to say but if you paid 1K for a homeowner saw you were taken, you could have bought an MS660 for that !
   / Chainsaw Bar Oil ?? #56
Heck even for the saw I bought I thought 1300 was a lot of cash ... but I haven't had anything slow it down yet ... and cant argue about having more power =)
   / Chainsaw Bar Oil ?? #57
I thought you were speaking of a Sthl 390 too; I about crapped my pants.
Thanks for clarifying. My MS660 cost just over $1000 US with an extra bar
and 3 chains per bar.
Same with my 660 that saw is a beast. Rips through wood like a raped ape.
It is called Paratac, it is polymethylmethacrylate. I have been in the lube
business for almost 20 years I love reading threads like this. I have learned
everyone has their opinions when if comes to lubes and seldom will they
change.
It simply comes down to bad oil is better than no oil, the correct oil however
is the best. I purchase the Stihl mineral oil based product locally for ~$10
per gallon. The high end biodegradeable Stihl is a great product and should
be for $40 but that is what biodegradability will cost you, it is mandated by
law in Germany that you can only use biodegradable oil in a chain saw.
   / Chainsaw Bar Oil ?? #58
Hi guys
I know a few old farmers that use second hand oil. They just use a bit of sash cord or non synthetic rope and drop it into the used oil drum as a wick letting the other end drip into a clean container. Only clean oil travels along the wick so there are no wear issues from contaminants. They have used it in my uncles case for 20 years and he has still has the same bar on the saw.
cheers
John
   / Chainsaw Bar Oil ?? #59
Around here,(eastern kansas), Stihl brand...from a Stihl dealer is $10.50 per gallon for both winter grade (thinner) and summer grade bar oil (thicker). That's all I'm going to use on my brand new Farm Boss. The old Homelite saws use whatever the discount stores sell...The 30 year old 150 AO throws bar oil everywhere (???) and the 13 year old d3850b gets stopped up all the time (???)....and I wished that I knew why.:eek::eek::(:(
   / Chainsaw Bar Oil ?? #60
As was said earlier, none of this will change anyones mind, but, I've noticed that the bar, chain, and sprocket tip all run hotter with used motor oil.
I use bar oil only after seeing that.
GALFRE GS300/2 - 2 Wheel Rotary Hay Tedder (A55218)
GALFRE GS300/2 - 2...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
201935 (A54756)
201935 (A54756)
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
UNUSED LANDHONOR FW-13-15000G HYD CABLE WINCH (A54757)
UNUSED LANDHONOR...
