FEL Tractor Crane *Proof of Performance*
   / FEL Tractor Crane *Proof of Performance* #31
Sons: Nice...interested in the concrete "door jambs" ...what determined them? Did you use some std plans?
   / FEL Tractor Crane *Proof of Performance* #32
This is an interesting subject. If you look at that 20' pole hanging from the bucket of that tractor, most people's first instinct would be to say it isn't safe. That's exactly what I thought when I first saw it. You're using the machine in a way it clearly isn't intended to be used, so of course people are going to say negative things about it. You'll get some who support it and some who won't. I don't see any reason to insult either party for their beliefs on the subject. Just because somebody sees this and disagrees with it doesn't make them less of a man than anybody else. It's a forum, criticism will come out sooner or later, and definitely sooner on more extreme things (such as a 20' pole hooked to your bucket, for example).
With that said, I never saw the previous post about this so I'm wondering how it all works (without tipping the tractor over, etc). I had a full bucket of dirt, about an inch off the ground, made a very slow, tight turn on dead-flat ground and my tractor started tipping over. So then, how can you lift all that weight that high and 20' out from the bucket without incident? Did the rear end of your tractor ever bob, even slightly?
Good job on the building, I'm also intrigued by the concrete door jambs. I don't think I've ever seen them done quite like that before. It looks good so far!
   / FEL Tractor Crane *Proof of Performance* #33
I use a boom pole like that and have a piece of plywood with four corner cables on it attached at the end.
I can put up to 2 bundles of shingles on it and lift it right up on my roof. sure saved my back, and I would say its safer.Not to safe carrieng a bundle up a ladder..LOL
   / FEL Tractor Crane *Proof of Performance* #34
My guess is that he is moving the tractor very little on and on smooth ground after lifting. Also there would not be an need to lift high until very close to position.
Also from the roof of his tractor I am guessing that is a TLB with a heavy backhoe on the back for a counterweight.
   / FEL Tractor Crane *Proof of Performance* #35
heavy loaders usually lift from the fixed axle end. not saying whether it will or won't tip over, but less likely to if you have shims or blocks restricting movement of your front axle.:)
   / FEL Tractor Crane *Proof of Performance* #36
Joe,
My only resource was archived plans off university websites for inspiration and a look into how things used to be done. The door pillars arose out of my reasoning that a 16' opening in the end of a 30' barn had to compromise its racking strength. So I ran the foundation up to the top plate 4 feet either side of the door. I do tend to overbuild to compensate for my lack of engineering. As a mechanical contractor I do have a lot of exposure to building systems and a lot of friends in the trades and I pick their brains for most of this stuff.
Regarding the safety of the boom pole, it came down to a matter of necessity. I certainly would never presume to recommend any of these extreme modifications, but we all have to evaluate our own risk aversion and all have to accept responsibility for our own choices. I am not willing to do nothing because there is an element of danger, I do all in MY power to minimize that danger.
I will yield the soap box now as I am not SO egotistical as to think everyone should agree with me:) I realize when I put myself out there that I am inviting scrutiny, but I can honestly consider others recommendations and still choose to do it my way, it doesn't mean we cant be friendly.
Many of these boom loads are much lighter than a bucket of dirt, and I always move as little as possible and make great use of my backhoe for counter balancing. I also do dry runs and performance tests to get the feel of what my tractors limits are. But in the end, ya just got to get er done.
A few more examples:
   / FEL Tractor Crane *Proof of Performance* #37
59,
Nice work. I like your design.
What keeps the boom from tilting back on you? Is it back-bolted to the bucket?
   / FEL Tractor Crane *Proof of Performance* #38
Primarily I just keep the load and boom angle well forward. I do have a 3/4 inch bolt thru the bucket into the end of the boom tube, but its only purpose is to keep the end from shifting side to side. The mating cleat is inline with the bucket edge and all other non-inline (downward) forces are handled by the chains.
   / FEL Tractor Crane *Proof of Performance* #40
It just seems to me that if you have say, 5000 lbs of tractor and BH behind the pivot point, and that being the front wheels, that you could have 5000 lbs on the front side of the pivot point. If he did exceed the 5000 lbs on the front, then the tractor and BH would start to tip. Now if the BH were stretched to full reach, and still off the ground, he could lift even more. Now, consider this, if the curl of the bucket cylinders curl 3000 lbs, when the tip of the boom moves closer to the front wheels, the load becomes less. The objective then would be to curl the load and lift, and drive to the set point. Just my view point on the lifting rig. It apparently worked, and worked well, so congratulations to 59 Sons.
Club Car Carryall 2 Gas Utility Cart (A55851)
Club Car Carryall...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2016 Lincoln MKC SUV (A55853)
2016 Lincoln MKC...
2015 FORD F650 XLT SUPER DUTY 24' BOX TRUCK (A57192)
2015 FORD F650 XLT...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
2015 Chevrolet Cruze Sedan (A55853)
2015 Chevrolet...
