Need Horse Trailer Opinion
   / Need Horse Trailer Opinion #11
Lifting the trailer should be fairly simple as long as the torsion axles are not welded on. If bolted on just make up some blocks the amount it needs lifted and get longer bolts. Drop the axles, slip in the blocks, then torque down the new hardware to spec.
Chris
   / Need Horse Trailer Opinion #13
+1 what Farmer said. Personally, I'd lower the truck but that's the old man in me. So take that for what it's worth!:D
That would be my preference too. Horses really don't like stepping into a higher trailer.
Have a ramp.....:thumbsup:
There'll be no lowerin'.....lowerin's for Honda Civics. :cool:
Working on 16" 235/85's right now.....wont be plum level, but close.
Really appreciate all your input, especially so quickly. Thanks.
-Jer.
   / Need Horse Trailer Opinion #16
-Jer.
I have mixed feelings about ramps on horse trailers. Some horses like ramps even less than stepping into a trailer. Plus there's the added pain of working around one. You need more clearance behind your trailer to get your horse out. This is a problem at shows and events, but it can also be a problem at a trailhead.
   / Need Horse Trailer Opinion #17
-Jer.
Be careful just putting on bigger tires. I have done this for a few of my customers and now refuse to. You will lose 1/3 or more of the breaking ability. Its all about leverage.
Chris
   / Need Horse Trailer Opinion #18
Based on your photo, I don't see the slope being all that bad. I have seen much much worse. What kind of miles are you looking at hauling?
I would be a bit nervous about the top of your bed.
FWIW, I used to have a Sundowner 4 horse slant with the ramp. I much preferred a BP two horse straight I had years ago with a drop axle. The floor was level and only maybe eight inches off the ground.
Hmmmm.... Never thought of that. I'm not super experienced with trailering, but I have struggled with loading and unloading with a step.
I'm gonna try the ramp and see... I'll report how Hank and Bitz like it. Bitz is a pony, so I think she'll be a fan.
-Jer.
Chris
That's a good point.....I'm gonna do it anyway as the trailer needs rubber and it should allow me to avoid fab-ing a lift.
I'll let you know if it causes issues.
-Jer.
Case Axial-Flow Combine Wheels NO RESERVE (A56438)
Case Axial-Flow...
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
Cushman Electric Cart (A55851)
Cushman Electric...
CATERPILLAR 246D3 SKID STEER (A60429)
CATERPILLAR 246D3...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
207276 (A52708)
207276 (A52708)
