At Home In The Woods
   / At Home In The Woods #2,281
We had a similar painting experience, and one of the painters was my neighbor. I ended up doing most of the downstairs trim paint.
My painters would put the wood-putty stuff in the nail holes with their finger, leaving a little dimple. I put in it and then when it dried sanded it with a block and piece of sand paper, and on some had to do a 2nd pass. They genuinely thought that leaving a dimple was the right way to do it because it made it easier to remove the trim if you had to.
They also used huge amounts of caulk at the border of the trim wood and drywall. Looks good but all caulk cracks with time. Finally, they pushed their rollers for too long on the walls and there were lots of places with fuzzy roller bits. They were overly frugal with their new rollers.
I talked with some folks who had used them before and they said they were happy. Yet at the open house we had for the place just before we moved in, many commented on the difference between the upstairs and the downstairs paint.
It's difficult when someone doesn't understand that their work is not up to the quality you want. I get along fine with the neighbors because it's all down to how you tell someone that you're terminating the agreement. They haven't changed how they paint, they just think I'm particularly fussy (and they are probably right).
Sand away at the bad stuff and use that as a "primer coat" for the next guy. You could also just prime some areas since time is scarce and then paint after the CO, depends on the room.
I suspect you've figured out by now than when any trade has to do even a little bit of work from another trade, it rarely goes well. So painters fixing trim problems or mudding up a drywall area is bad. Plumbers can't nail a blocking 2x4 worth a hoot. I'd get your nail holes wood puttied and sanded and not leave it to the painters. This has come up before in your journey, the problem of areas that fall between the cracks end up in the GC and home owners lap.
One last paint comment: Other than the baseboards, we used no caulk on the trim. Yes, you can see a small crack or gap on windows and doors if you look for it. But I've seen caulked houses and after some time the caulk cracks and it's very hard to remove without pulling up drywall paper or dinging the trim. So I took the devil I know vs. the devil I don't. There were a few places where the gap was soooo bad and it was (for some reason) very apparent where I did caulk, but it was flush with the wood and square-up against the drywall.
If a crack bothers you down the road, you can always put a little caulk on and paint it. It's not so easy if existing caulk cracks and you have to remove it to fix it.
The baseboards we have are simple 1x6 pieces with a 1/4" rounding. We used those because we didn't want to have to find a specific moulding style if we had to repair some, and it fits in with the simple scheme of the home. Because of the angle when you look down at them, any gaps are very apparent. So a very small amount of caulk was used, and it was worked into the gap so the intersection of the wall and trim was a sharp 90 degrees. It will crack someday, but the crack will be smaller than what was there to begin with. I used the plastic plates used for auto work with bonder to get a clean seal between the wall and the baseboard.
If the definition of insanity is doing the same thing over and over and expecting different results, caulk is the most insane building material there is.
Pete
   / At Home In The Woods #2,282
Painting Woes
Wednesday evening, my wife and I inspected the trim painting. The quality of the work just wasn't up to par. You could see every nail hole in the doors. In several places the edges of the trim around the doors felt like sandpaper. The trim on top of the doors didn't get primed or painted. The workmanship was poor in the harder to see places like the insides of the closets. The trim carpenter had put some wood puddy on some trim and was waiting for it to dry before sanding. The painters painted over the rough wood puddy before it got sanded. Defects in the door trim got painted without filling the imperfections first. Obvious drywall dings in the wainscoting below the chair rails in the dining room/office got painted without touching up first. All these issues were outstanding after the painter said he was finished painting the trim.
On Thursday the doors were scheduled to be painted. When the painter arrived in the morning we told him the quality of the work didn't meet our expectations and we didn't want him to do any more work. He asked why and we mentioned a few things. He offered to fix them but I told him we wanted to settle up and part ways.
The tough thing is he genuinely thought that his work was good. If there had just been a few things that had been missed, we would have given him a chance to fix them. But the quality of the work was so far away from our wishes that we didn't want him to do anything else that we either would have to have re-done or couldn't fix at all after he had touched it.
The painter seemed like a likeable guy. He obviously wanted the work and did not get indignant or hard to deal with when we expressed our concerns. He just couldn't believe that the quality of the work was not good enough. He asked if there was something else that happened or if there was something we weren't telling him. He was baffled that we were letting him go.
Letting him go was painful; both my wife and I felt bad for the painter and his crew. After we let him go, my wife started having misgivings because we pulled the trigger so quickly and didn't give him a chance to fix things. However, after seeing marred walls that got painted in the office/dining room on Friday morning, my wife was glad we didn't keep the painter. In addition, we hated to see all the trim carpenter's beautiful work get covered up by such sloppy painting.
So now we are trying to find a painter. The trim carpenter knows a painter he highly recommends so we are attempting to work something out with that painter.
Sounds like your painter was like a few (not just painters) I know around here. They have no idea what a quality job requires. They mostly work for builders that don't care as long as they sell the house & get paid.
I'm pretty soft with this type of thing and would have explained it to him and had him fix what was wrong. If it still wasn't right he would be gone. Seems some times that's all it takes to get them on the same page. I would usually blame myself for not communicating what was required clear enough.
On the other hand I can understand your frustration with him and wanting it done right. Drywall, paint, trim and floors is what people will see when they walk in the door and it sure is nice when everything looks good. A bit of sloppy trim or paint can mean the difference between nice house and wow.
Being in the contracting business makes me look at things like this in every house I enter. If I see really nice work I'll ask who did it. Sometimes when the work is bad I may ask just so I know who not to hire.
Your trim guy looks like someone I woud be glad to use. Older fella that takes his time and does things like it was his own house.
   / At Home In The Woods #2,283
We trim carpenters (the good ones anyways) are particular about painters. They can make all our hard work look terrible. Having said that, if your carpenter, who I think is a good one, has a painter in mind I'd say you ought to go with him.
My post must have come across wrong. We all know accidents with tractors happen. My safety police comment was more related to the extraction technique. There was a lot of energy stored in that cable and if it snapped it would have been a very dangerous situation (based on the pictures). Friends or not I was surprised someone more passonate about safety than I am did not point it out.
IWBWI,
Your comment about straddling the cable didn't come across to me badly or as a "safety police comment". No worries. Thanks for being part of the thread.
In actuallity, if I remember correctly, my neighbor didn't straddle the cable for long. It may not have had serious tension yet at that point. The hill was steep there; I remember his talking about the difficulty getting a good footing where he could pull on the come-along handle.
Obed
   / At Home In The Woods #2,285
walleyed said:
lol Thats funny.
Of course we all know a few guys that should be fixed in this way.:eek:
Um... Don't they make the Darwin Awards for those folks?
:laughing:
J
   / At Home In The Woods #2,286
Should we page the safety police....
Seriously, there is alot of overly commentatiousness about safety sometimes....
J
Natural Gas Line
The gas company ran the gas line the last 100 feet from the driveway to the house. What I didn't know was that the gas line has been pressurized for the past year. In order to connect two pieces of pipe, they put a clamp on the line to stop the gas pressure. They then used a tool to trim each end of the line to a perfect 90 degree cut. Then they pushed the two ends together and melted them together to bond the to sections of pipe together.
Below the water spigot you can see where the gas line from the house exits the house. There is a pressure meter on the in of the pipe. I have about a foot of dirt to add to this part of the grade which will put that pipe below grade. The gas people highly recommended not putting that pipe below grade because it will rust and cause a leak. So we need to raise the pipe. When we finally got our H&A guy to return our call, he said it would take about 3/4 of a day for him to raise that pipe. The H&A guy continues to be my least favorite sub. He only has a little bit of work left to do but is being very inflexible and unresponsive. Six hours to move a foot higher is a bunch of bologna. This is a case of a sub who thinks he has you backed in a corner so he sticks it to you with the charges.
   / At Home In The Woods #2,289
It always seems that the sub you are likely to need in the future turns out to be dis agreeable.....I have found that they can be very short sighted, as it is expensive to get any service people in the future, no matter what the problem....In your location I would be most concerned with the cold, so plan on a backup in case the furnace gives you a problem......As you have been so involved in your house, I would bet for your peace of mind, it to be prudent to learn how to replace a blower motor, as you are more than capable...This is also why I like two systems instead of one :) A faithful follower Tony
   / At Home In The Woods #2,290
You can move that pipe 1' higher yourself, with less problems than the sub is making, and even if you have to buy every single tool you need it will cost you less that the sub would charge.
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
set of 4 tractor trailer tires Roadforce (A56436)
set of 4 tractor...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
