Taking a break...
/ Taking a break...
...I would think you could buy one of these brackets from KK.....and it may provide some solutions for others. I sure like mine....so I thought I would post this...
The problem I had is when the link you've shown that is pointing UP flips down and rams into the "A" frame... Granted you have 2 bolts holding the top of the "A" frame but you get the idea (I hope).
/ Taking a break... #22
My MX6 has "knee-action pivot" too. That plus hydraulic top link for when I cross my emergency spillway on the pond dam. I'm considering getting an additional hydro top link without check valves so I can float it, best of all worlds.
teg, glad to see the Piedmont broom straw grass knocked down. Looks better and is not a fire hazard. Only downside to mowing that stuff is I have to blow out my radiators with air when I'm done, lots of dry stuff.
Field looks great! Your break was a success :thumbsup:.
Pete
/ Taking a break... #24
My KK rotary cutter came with a knee-action "pivot" affair to attach to my top-link. It allows the cutter to lift up about 10"+ to clear obstacles.....but limits the cutter from lifting too high. You can pick up the cutter...just like with a top-link.
I wish I had a better pic.....also, it would be easy to make one of these.
My cutter has a pivot in the two rearward "down" straps.
/ Taking a break... #25
On a side note: Those R1's look unusually large.
/ Taking a break... #28
CompactTractorFan said:
They look like they are the size of R4's, but the treads look like AG.
Yea...
I have the 3400 and the industrials for it and the 2800 have that look..
The ags are skinny...
/ Taking a break...
...It sets the cutter height and keeps that sucker from coming up ... with out it it can roll right up your back side.
I look at mine without the toplink like a tow behind brush cutter... just can't imagine 3 to 500 (???) pounds getting kicked up like that. It's only grass...
Now I see that the rear treads seem shallow like R4's, but the front treads still look deep.
I think you are talking about the green tractor photo... and RT is talking about the orange ones?
/ Taking a break...
..teg, glad to see the Piedmont broom straw grass knocked down. Looks better and is not a fire hazard. Only downside to mowing that stuff is I have to blow out my radiators with air when I'm done, lots of dry stuff...
Hey Pete, the truth is I have to blow it out several times when I mow. I over heated my tractor twice... I don't plan to repeat that mistake a third time!
/ Taking a break... #32
Understood ... I was backing into some brush a hidden object apparently hit the stump jumper and before I new it ... well it was up again the back of the tractor with a destroyed PTO shaft. Lets just say I won't do that agian.... Top link is always in place.
I use the same set up as teg except with a L3400. If you notice, with the quick hitch the RM CANNOT come up more that a foot or two, it will hit the QH at the point where the hook usually goes.
DRL
/ Taking a break... #34
And I the orange... Is there really such a beast as a green tractor?
:confused: :)
Or is a green one what happens when an orange tractor gets sick?
:p
1939 Chevrolet Deluxe Coupe (A65640)
1939 Chevrolet...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
