4&1/2" angle grinder reccomendations?
   / 4&1/2" angle grinder reccomendations? #52
While we're on the subject, I saw this deal today...
Bosch 1375-03H 4-1-2-in 6 Amp Small Angle Grinder 2-Pack with Free Grinding Wheels
Any opinions of that Bosch model? The fact that they're selling them in a two pack makes one thing that even the manufacturer considers them a consumable.
As a rule, Bosch makes pretty good stuff. These are fairly light grinders but should do fine if you don't lean on them too hard. The sale by the pair doesn't indicate "Consumable". A well equipped Fab table needs at least 3, preferably 4 grinders each with different wheels and brushes.
   / 4&1/2" angle grinder reccomendations? #53
Keep in mind the same company owns SKIL..which was formerly a good name, but now its right about Harbor Freight.
   / 4&1/2" angle grinder reccomendations? #54
3 was always a good number for me. Wire wheel, type one disc, sanding
disc. I liked the Milwaukees because you could detach the cord from the
grinder, forgot what they call it. When welding you have enough cords
cables and hoses laying around, being able to share one power cord with 3
grinders was a plus for me.
   / 4&1/2" angle grinder reccomendations? #55
We have a bunch of Metabo grinders at work and they seem to hold up pretty well. So do the older DeWalt grinders. But no electric grinder is going to really take the kind of abuse metal fabrication can really dish out. AIR grinders are where it's at and unfortunately, so is the price. :( I had an Atlas Copco LSV38-ST12-125 5" angle grinder for a demo. It was really a 4-1/2" grinder that would also squeeze in 5" wheels, and it was very easy to handle as the body diameter was much smaller than any electric grinder.
The air motor contained a governor that would maintain wheel rpm as load was applied. This, in theory, will make the consumables last longer and perform better. All I know is that it had an insane amount of power and you'd better make sure the wheel was on TIGHT and also have the wheel retainer lock installed. When releasing the trigger fully, the wheel stops NOW, and I had the wheel spin right off and dance across the shop floor for a LOOOONG way. :ashamed:
So why doesn't everyone have one??? Two problems - a $900 price tag and enormous air consumption - somewhere between 30 and 50 cfm! I've got a couple of 100hp compressors at work that will do the job, but there aren't many small shops that have that much air available. But one air grinder, provided it is properly lubricated (both the air motor and the gearbox), will outlast many electric grinders and probably save money in the long run.
Therefore, I'll keep using my $20 Tool Shop brand grinder from Menards that has performed way beyond what I expected of it and still runs great. One tip - most of these grinders (especially the cheap ones) use some sort of Mongolian Yak fat for grease. It is way too thick for the high speed gears and causes excess heating. I clean this out and replace it with Mystik synthetic blend grease as it has a rather light base oil viscosity of around 68 cSt. Most other greases have base oil viscosity in the 180-220 range, and some are over 600. This is not the same as #1, #2, etc. grade grease. You can have a "thin" grease with thick base oil and vice versa. Electric motor bearing grease is another good type - usually with base oil in the 100 cSt range like Mobilith SHC 100.
Chris
   / 4&1/2" angle grinder reccomendations? #56
Metabo at work although Millwaukee used to rule. An older Black and Decker at home. Very useful but potentialy dangerous tool. Be careful.
   / 4&1/2" angle grinder reccomendations? #57
Orginally posted by Mark@Everlast;
Default Re: 4&1/2" angle grinder reccomendations?
Quote:
All shops around here use 4.5s,7's, or 9's, with an occasional 4 thrown in.
It might be a regional thing...but I can count on 1 hand the times I have seen a 5 inch grinder in use
up here it's the opposite... 4 1/2 discs very tough to find. also, if you work construction, certainly in bc or alberta, you are going to find 5" everywhere. i have tried 4 1/2 but the disks themselves don't last very long. its the same story as exhaust system diameter... a little makes a lot of difference. 7" are just too big for most on-site type applications. 4 and 4 1/2 inch low amp motors don't hold up to the strain, i still remember the smell of my 4 1/2 walter the day it died. then again, i remember the smell of a few cooked makitas too... all the same, my experience tell me 5" is the most efficient size, both for disk and motor.
far as grinders go, i have tried walter (metabo) and the generalization that germans make good stuff does seem to hold true, but the price is high and the ergonomics are questionable, same with fein brand. makita hit the sweet spot, both size and useability wise. it's a just plain comfortable grinder to use... add that to a mid-range price and good quality and tradesmen up here are more than willing to overlook the pita guard setup. some newbies complain about the disc locking nut but that goes away once they figure out that when you change a disk you just run the nut on finger tight and give the ever so slightest torque using your hand and the grinding disk.
it doesn't matter what oil sands facility you go into, you will see 9005b's everywhere. around here it would be a pretty safe bet, if a rig has an s/a on the back, it has 9005b's in the cabinets. actually, that probably holds true no matter what kind of welding machine is on the back.:)
   / 4&1/2" angle grinder reccomendations? #58
My dad has got a Makita and it's been going strong for at least 15 years. He bought it used at a pawn shop.
I have a workforce angle grinder that I bought at lowes a few years ago on sale for $15.00
It's been a great grinder for the price. I had it looking really used the same day I bought it. That's how hard I used it. I didn't think it was gonna get through that day. But it did and still is working great.
Chad
   / 4&1/2" angle grinder reccomendations? #59
Not possitive but I believe Makita is still Japan. Still, Kind of higher end price wise. On the cheapo units, It's usually the brush springs that burn off or the triggers burn up right away. At least with some of the prior listed brands you can buy new brushes and switches for them. I guess the best policy is to not lean on them too hard while they are grinding or they will probably fail sooner than later. I have an ols 6145 Milwaukee from the 90's that gets used 3x more than my newer Milwaukee and the newer one has already failed and been repaired. Go figure.
Look at the the head if it, all mine say made in China.
That must be why you might find two 5 inch grinders on a shelf under a 2 inch pile of dust within a 100 miles of here and even have to look just as hard for a 5 inch disk.:confused2:
It might be a regional thing...but I can count on 1 hand the times I have seen a 5 inch grinder in use.
I have 5 Makits 3 ea 4.5", 1ea 4" and 1ea 5", 1ea 4.5" BD that was given to me...vibrates, gets hot & is just too big in dia. I'm not fond if it. I also recently recieved a Ridgid 4.5" grinder that is really comfortable, the handle is completely different from the standard
grinders, the switch is kind of a pain but it is still comfortable to use.
My oldest Makita is 8yo and still works just fine.
I did purchase a 20.00 Northerntool 4.5" grinder once...it lasted 6mo with light use till it let the smoke out.
   / 4&1/2" angle grinder reccomendations? #60
I caught the wife wrapping Christmas packages today, and she did not want to wrap the biggest one, so she gave it to me, It was a Ryobi 4 1/2 angle grinder with the 90 degree adjustable grip and the 3 location handle positions. It also has a no tools guard adjustment and onboard storage of the wrench in the handle. Kinda of a Jimcrack sort of thing, but I used it today and kinda like it.
James K0UA
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
UNUSED FUTURE MINI EXCAVATOR RAKE (A57193)
UNUSED FUTURE MINI...
1994 International 3800 Bus (A54814)
1994 International...
2017 Ford Expedition SUV (A55853)
2017 Ford...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
