Chainsaw Bar Oil ??
   / Chainsaw Bar Oil ?? #61
TSC has their brand bar oil on sale for black friday for $5.99.
   / Chainsaw Bar Oil ?? #62
I just put some new motor oil in my junk plastic Poulan Lowe's special because I was out of chain oil. The saw was about half full of chain oil so I topped it off with motor oil. That saw gets abused and if I dropped several hundred dollars on a saw, I'd never use anything but bar oil. With this one though, I'm not to worried about it. The downfall is, the oil slings off of the chain a bit more than I care for, but it worked in a pinch.
   / Chainsaw Bar Oil ?? #63
That's when I found out the difference.
I was helping a neighbor cut up some trees and ran out of bar oil. He said, here use this, it's used motor oil that I filtered. I figured.....what the heck, I'll give it a shot.
My bar got hot, the sprocket tip got hot, chain got hot, and it didn't cut well at all.
   / Chainsaw Bar Oil ?? #64
I agree with Don87,
Last year I started using 5-30W motor oil because I had it on the shelf for several other things and vehicles. I don't use the chainsaw a lot, just for my own firewood. I wore out a bar sprocket tip. Local repair shop didn't have a new tip so I bought a new bar. This year I still used the same motor oil and the chain would get very hot a came loose during the first cut. I would keep adjusting the chain and go again. Sometimes the chain would come off. It also did not cut well at all. The new tip wore out and plain to see the bar had a lot of wear on it. The drive sprocket was bad shape now too. The shop put a new srocket tip on the bar and dressed up the edges on the bar. He ordered a new drive srocket for me which I put on when it came in. While I was there I picked up a gallon of bar and chain oil. After using the bar and chain oil this season, I have not had any problems at all. The chain doesn't get hot and loosen up anymore and it cuts good. So I will continue to spend a few dollars on the right oil now. Just my own opinion
   / Chainsaw Bar Oil ?? #65
I know some people around here that deep fry there turkeys around this time of year, I get there 3+ gallons of peanut oil for free. I strain it through cheese cloth and it works great for bar oil, eco fine and a couple of gallons lasts me all year. Several loggers in the area take all the rest off my hands.
   / Chainsaw Bar Oil ?? #66
I've read all 7 pages of this thread and it amazes me. Now, I can understand using some other kind of oil in an emergency but there are people on here who spend hundreds upon hundreds of dollars on a chain saw and then try to save a buck by using any kind of junk oil in it that they can get their hands on. Peanut oil, used motor oil, hydraulic fluid, why not extra virgin olive oil or Crisco? Come on, somebody has to have tried that ....
Spend the extra couple of dollars and get the right oil for the job. End of story!!!
   / Chainsaw Bar Oil ?? #67
I agree^^^
i run all Stihl saws and would never think of using a different oil,bar oil is desighned......for......this.....use,,it has tackifier's in it so the oil is thicker and sticks/hold on better to the bar and chain with out slinging off as much thus protecting against wear better.
i wouldn't even use another oil in a pinch,the saw would stop till i had some.
   / Chainsaw Bar Oil ?? #68
I agree^^^
And if I had an expensive saw I would not use anything else, either. But it got me through until yesterday when I went and bought a bottle of bar oil. A lot of people use motor oil and have for years, with no issues. Guess it's whatever you want to do, it's your saw...
   / Chainsaw Bar Oil ?? #69
To each is his own,, them are the people that probably use 2 stroke oil in there car engines it's oil it'll will work right?
   / Chainsaw Bar Oil ?? #70
makes it rev up a little too quick though and sound like a banshee.:laughing:
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
John Deere 6300 (A60462)
John Deere 6300...
JOHN DEERE 4450 TRACTOR (A60430)
JOHN DEERE 4450...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
