Ho do you know...
   / Ho do you know... #1
retiredmgn
Gold Member
Howdy folks,
Seems like a nice site. Like to hang around for a bit.
I just traded a Kubota 19 hp for a HST JD 3238. I bring in 6-7 cord a year for firewood. My question is this, what can I use as a rule of thumb to determine if a tree is safe to skid out without over stressing my tractor. I've been going on the idea the release valve will allow fluid to pass before any damage will happen to my tractor. After reading posts here I'm no longer sure.
I like to cut trees in the 8 - 10" range.
Thanks
Mark
   / Ho do you know... #2
i have a fifty hp.I haul five at a time with my log winch.Full tree length.8 to 12 inches at the but .Some trees are forty five feet long
   / Ho do you know... #3
Mark,
How much power does your tractor have and how much does it weigh? I could look it up myself, but I'm too lazy. How do you hitch the cut timber to your machine? Do you have FEL, ballast, chains, type tires? What's your terain like? Hardwood or softwood?
-Jim
   / Ho do you know... #4
Not sure about the HST, but as long as you are pulling from the drawbar, I think it will be safe for anything that you can move.
If you hook to the drawbar and it pulls, you are good, If you spin the tires, it is obviously too heavy and needs cut down. But as long as you can move it, I dont think you are going to hurt the tractor.
   / Ho do you know... #5
Howdy folks,
Thanks
Mark
If you are lifting them to skid, keep the front tires FIRMLY on the ground to be safe. If you are simply dragging them, traction will be the limiting factor.
   / Ho do you know... #6
I would say you can pull as much as you can without stalling or running out of traction.
   / Ho do you know... #7
Welcome to our and maybe soon to be your world. LOL be careful it is addictive once you get on here. zman :D
   / Ho do you know... #8
May depend on couple things.
What type of ground..hard or soft,flat or slope,log form or w/limbs.
Last thing you want log/logs breaking traction and slam into your tractor..cause damage or worse.
I'd try couple couple logs to see/feel the handling than go from there.
   / Ho do you know...
Well ya, I can pull a bunch of stuff now (although I ain't gona try what you're listing with your 50 hp). What I need to educate myself about is at what point am I stressing the machine. I want to be able to keep pulling several years from now.
   / Ho do you know...
Mark,
-Jim
Howdy. I need to back up here I guess - (you mean everybody isn't thinking and knowing about MY new tractor?? Probably not :cool:
Tractor is John Deere, 37 Hp, FEL, AG tires loaded, chains.
Terrain is basicly flat. I hook to the drawbar on the TPH to try to get the log butt up out of the dirt. Only cut hardwood.
Don't want to raise any hackels here but I'm thinkin' that Kubota B8200, 19 HP, HST with unusually wide rear tires could pull more than this JD. That's my concern :confused:.
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
