Loader Bx 23 utility lights
   / Bx 23 utility lights #1
twinsticks
NJ
2005 BX 23
I have a 2005 bx 23 I would like to put 2 lights forward and 2 lights facing rear gonna attach to rops with clamps and wire loom .. What is the max wattage the tractor will handel ? I am going to wire them on 2 different circuits off the battery with relays as every one knows you cant see forward with the front loader on or up really high... : What will the stock altenator handel
   / Bx 23 utility lights #2
I don't have the answer to your question, but this is what I did for rear-facing lights - I didn't even put a relay in! If anyone does know the max, that'd be great to know. Best of luck and post some pics when you get finished! :thumbsup:
   / Bx 23 utility lights #3
Amps = Watts/Volts.. The generator on the BX22 will produce 14 to 15A and 14 to 15v @ 5200 RPM, not sure what engine RPM is needed to achieve this RPM on the generator though.. (Maybe different on the BX23, but not likely.. Look in the workshop manual under charging system to know for sure)
If you were to use all the available power.. Amps * Volts = Watts. 14A * 14V = 196 watts. But you have to exclude to load already on the system..
Head Lights 45w * 2 = 90.
Hazards 20w * 2 = 40.
Tail Lights 3w * 2 = 6.
Turn Signals 20w * 2 = 40.
So if you don't include the Turn and Hazards (unless you use them all the time) 168 - (90 + 6) = 100w available to use. Not much. And you should always leave some for the charging system to use to keep the battery happy etc.
What I ended up doing was to replace the headlight switch with a turn signal switch. I wired it such that if I move the switch forward the head lights turned on but the work lights turned off, and if I moved it backwards the head lights turned off and the work lights turned on. And in the middle both head and work lights were off.
Happy wiring :thumbsup:
   / Bx 23 utility lights #4
Its not going to happen... For forward and rearward facing.. At wide open throttle it could handle 2 45w lights... But you dont run them full throttle all the time..
Even at 2 45watt lights youll not be charging battery at idle anymore but draining it.
   / Bx 23 utility lights #5
I have a BX23 and it has a dynamo rather than an alternator. I have an LED light bought through Northern Tool and I am happy with it. Since the LED lights use so little power you could easily run 2, and probably 4 at the same time. They are very bright, but a bit pricey.
Here is a link to where they were discussed, and there is a link there to the light.
http://www.tractorbynet.com/forums/john-deere-owning-operating/188596-led-lights.html
Okay if it wont handel it what lights could I use do they make led,s they would draw alot less or if not i can run the fronts then the back sepretly ... Do they make a bigger altenator for the bx 23
   / Bx 23 utility lights #8
According to my Jan. 2007 Kubota Wholegoods pdf, the BX23 can take the BX7310A high capacity alternator that came standard on the BX24/25. It's a 40 amp alternator. Check with your dealer for pricing.
Monday I will call the dealer and get a price on one
How hard is it to install anybody ever do one?
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
Shell Vintage Decorative Fuel Pump (A55853)
Shell Vintage...
30KW GENERATOR (A58214)
30KW GENERATOR...
