actual repair cost by hour usage of skid crawler undercarriage
   / actual repair cost by hour usage of skid crawler undercarriage #11
Just to clairify. The Terex/ASV undercarriage package part # 0403-531, as found in the other post, does fit the 2006 model RC-100. This package is a direct bolt on for all RC-100, PT-100, and PT-100 Forestry machines. The up side is that it is a PT-100 Forestry spec build. Meaning it has all the PT-100 upgrades including all metal face seals, upgraded frame, new tracks, taper bearings, improved outboard bearing and seal, and is complete with new sprockets. This kit would bolt right into a 2006 RC not only replacing the undercariage, but improving it to 2010 PT-100 design specs.
If your dealer has any questions they can contact Terex service department, or me directly and we would be happy to assist in the undercarriage needs.
Thank you,
Buck
   / actual repair cost by hour usage of skid crawler undercarriage #12
Yeah, for some reason the local CAT dealer here in WI is more expensive than the other brands as well. It's a shame, especially for the same parts. The price I was quoted for the undercarriage from the ASV dealer was for a completely assembled undecarriage that included both sides, tracks, rails, wheels, assembled sprockets, and outboard bearings. The only thing the package didn't include was the torsion axles and the drive motors and the drive motor housings. Otherwise, it was just slide it onto the axles, hook the drive motor hoses up, bolt the sprocket onto the drive motor and throw the tracks on. It is supposed to come shipped fully assembled sitting on the pallet. So your undercarriage cost would only be around $8.50 an hour if you changed out the whole undercarriage (which you wouldn't need to) every 1,000 hours.
Digdeep,
I'm in the market for an ASV RC50 or RC60...is your RC50 pre 2005 or 2006+? I'm leaning towards pre-2005 to take advantage of the lower weight (I want to run turf tracks)...do you have any advice on how to check out a used machine to determine undercarraige condition?
Tx!
Mark
   / actual repair cost by hour usage of skid crawler undercarriage #13
Have you thought of buying a 100 + hp 4x4 tractor and fitting a 3pl mulcher ? These running costs will break you . My TL100A New Holland tractor is 5 years old now and apart from staking some tyres , I have replaced the air and fuel filters a few times and that's it . It has never missed a beat and goes to work every day . I treat it terribly , constantly over loaded , one back wheel in the air often and I have never had a mechanical component off of it for repair . Spend some time on youtube and see if a tractor with a mulcher will do the type of work you have in mind . There is NO comparison between PTO horsepower and Hydraulic horsepower . A tractor is also WAY more versatile than a Skid Steer with the hundreds of attachments you can add .
   / actual repair cost by hour usage of skid crawler undercarriage #14
Digdeep,
Tx!
Mark
Mine is the lighter one too. I think just over 5000lbs. I have the standard tracks, but I did get to run a PT60 with the turf tracks...it was unfriggin real how much traction the machine still had and how little damage it did to the turf. I just can't justify the cost for the amount of time I spend on grass. As far as undercarriage condition, I would recommend that you call ASV direct. I have things that I would look for, but they have two guys in the service department named Tim and Cam that are really helpful when you have a question. 218-327-3434. they used to have a 800 number, but it is no longer working. Good luck. the RC50 has exceeded all my expectations other than I wish it would lift more so I could unload sod pallets. Oh wello, you can't have everything.
   / actual repair cost by hour usage of skid crawler undercarriage #15
I have seen this debate a 100 times, I don't think a tractor-skid steer comparison is worth a lick. I have owned both and can say both have just as many attachments/usage as the next. they both are good in moving product etc. What it comes down to is personal usage and preference. I have let my tractor go and and really enjoy the skid steer especially in tight spots{which will definately beat a tractor}. If someone asks about a skid steer they should get advice about a skid steer, if they ask about a tractor same rule applies. Now if they ask for a comparison the best advice possible is use each and find out which one they feel most comfortable using for their style of operating and work.
   / actual repair cost by hour usage of skid crawler undercarriage #16
Apples and oranges. I say you can't really compare the two. There is no level playing field. Tracked tractors are far superior in flotation, traction, low ground pressure, and drawbar pull, while wheeled tractors exceed in speed, agility, and lower maintenance costs. Skid-steers fall somewhere in the wheeled tractor category (except for tires).
As 20-20 suggested, there are just about as many implements available for either type tractor. I depends how much time you want to spend looking back over your shoulder.
FWIW: 1 horsepower = 745.699872 watts, and it doesn't matter if it's gasoline, diesel, steam, or electric. "PTO" and "hydraulic" come from one of those sources.
   / actual repair cost by hour usage of skid crawler undercarriage #17
I say again , there is no comparison between hydraulic horsepower and PTO horsepower . Once the cutter drum gets loaded up on a hydraulic mulcher the relief valve in the machines valve bank opens , oil flow and pressure drops and the drum stalls . When a PTO mulchers drum loads up , Black smoke comes out the tractors exhaust and full torque is applied to the drum . You cannot stall the drum unless you stall the engine .
And when I say a tractor is way more versatile than a skid steer , I was refering to a machine on a property , try plowing , cutting and bailing hay , mowing grass with a 14' Rhino or pulling a 10 ton feed out wagon with a skid steer . With the added advantage of being able to mulch trees and run a flail mower .
It is up to the OP to decide if it is of merrit to consider a tractor , not others .
   / actual repair cost by hour usage of skid crawler undercarriage #18
Digdeep,
I really appreciate the help...I'll give them a call tomorrow.
-Mark
   / actual repair cost by hour usage of skid crawler undercarriage #19
I say again , there is no comparison between hydraulic horsepower and PTO horsepower. Once the cutter drum gets loaded up on a hydraulic mulcher the relief valve in the machines valve bank opens, oil flow and pressure drops and the drum stalls.
Hmm, I guess this fellow doesn't know that:YouTube - RockHound Skid Steer Flail Mulcher
When a PTO mulchers drum loads up, black smoke comes out the tractors exhaust and full torque is applied to the drum. You cannot stall the drum unless you stall the engine.
Hmm again. We all know by now that black smoke means you are lugging the engine, wasting fuel, and not operating efficiently. Not good.
And when I say a tractor is way more versatile than a skid steer , I was refering to a machine on a property , try plowing (assuming you mean harrow?) YouTube - HOJA DOZER, cutting and bailing hay , mowing grass with a 14' Rhino or pulling a 10 ton feed out wagon with a skid steer . With the added advantage of being able to mulch trees and run a flail mower.
It's all relative. A skid steer can pull/push any attachment a tractor can with all things being equal (horsepower and weight).
It is up to the OP to decide if it is of merrit to consider a tractor , not others.
Very true. I am just reiterating my opinion and experience. Seems it was necessary.
Cat Challenger, which is kinda like a skid steer on steroids:
http://www.youtube.com/watch?v=Ase2nUB9E_8
12345
   / actual repair cost by hour usage of skid crawler undercarriage #20
Thanks for the post and videos Bob Rocks, I agree with you 100%, some folks just don't like to think/look outside the box, I was the same way at one time. I can only speak from my experience, and I can say my little skid steer is great in the woods{still need to get the OTT's}. The reason I like it more then the tractor is because it can turn on a dime and it is much more maneuverable. Plus the ease of operation compared to a tractor is nice, and in the winter plowing snow is also better. Again I am not trying to compare the two I don't think it can/should be done. For myself one machine is much better then the other, for someone else it may be the opposite.
Hey Bob Rocks, how did the OTT search turn out? Did you get them, if so how do you like them? I'm plainning on getting the steal ones, not so much for winter{chains work fine} but come spring I'll need them.
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2019 XL 110 HDG RGN TRAILER (A55745)
2019 XL 110 HDG...
2021 Toyota Rav4 AWD SUV (A55853)
2021 Toyota Rav4...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
MASSAGE CHAIR (A55745)
