USNative
I do get a kick out of everyone who thinks there tires are the best! Without ever getting on a tractor simply looking at them and using a little logic will tell you which will have more tractive force in different conditions. Doesn't mean the other ones won't work, just that they may not work as well but it may not make a difference if it gets the job done for you.
Also you don't know how much better you could do unless you experience more traction with a different tire, chains, loaded etc. R4's are a good all purpose tire, no doubt. More plies than R1's ie tougher and stiffer sidewalls. Harder compound = longer wear=less traction than a softer compound. Ever see a farmer out in loose material (dirt, mud, snow) with anything but R1's? There's a reason for that. Deep mud? Use rice tires. I would also tend to disagree with the post that said R1's have no traction in reverse. They DO have less than going forward, but I can still get out of some pretty good muck while in reverse.
Totally agree gerard, it all comes down to trial and error. The way I see it is that everyone here that has givin their input as to what works for them has different conditions they are working in therefore different needs. Also experience is a big help when it comes to operating the equipment in these conditions. A person with 10+ years of experience will be able to clear snow a lot easier than a person with say 2 weeks experience because they have learned the tricks to doing it properly and safely.
I live in Montana and we get alot of snow where I am and alot of winds which blows the snow to drifts but the snow is dryer then other places. My R4's have worked very well in my conditions but in other conditions may be a nightmare.
As long as it works for me I could care less if it has R1's, R4's or turf and mine works just fine the way it is for my particular needs. Now, if I ever get into haying and cultivating i may need a bigger rig with some AG tires on it !
