What GPM hydraulic pump is needed for 2" bore cylinder?
   / What GPM hydraulic pump is needed for 2" bore cylinder? #1
chad22
Kansas
Sears Garden Tractor
I bought one of these cylinders that's in the link for my backhoe that I'm building. It has a 2" Bore. I'm wondering what size (GPM) of pump would I need to make the cylinder have good retract and extend times?
Delvan Ag Pumps Inc 2 X 10 Tie-Rod Hydraulic Cylinder
Thanks
Chad
   / What GPM hydraulic pump is needed for 2" bore cylinder? #2
If you are talking about a small backhoe I would think 5 gallons per minute is about right.
Any pics of the placement of the cylinder would be helpful.
Craig Clayton
   / What GPM hydraulic pump is needed for 2" bore cylinder? #3
Thanks
Chad
Assume 1 in rod,
4 GPM = 2.04 sec extend
1.53 sec retract.
6 GPM= 1.35 sec extend
1.02 sec retract
At 2500 psi, push force would be 7854 lbs
pull force -----------5890 lbs
   / What GPM hydraulic pump is needed for 2" bore cylinder? #5
hey AKK, did you build that spreed sheet? I like it :thumbsup:
   / What GPM hydraulic pump is needed for 2" bore cylinder? #6
I could see some was in there and tried a 2500psi 5" bore....LOL....Tx sylwoody....Yes I make'm.....call it my X-mas gift to ya all....:thumbsup:
   / What GPM hydraulic pump is needed for 2" bore cylinder? #8
Got a little spread sheet here, try that!!
Enter you numbers in the green cells, GPM is a function of displacement and speed in this spread sheet...
BTW, Merry X-mas everone!!
Wow. that makes my spreadsheets look lame. Same results though. I am always comming up with new things to enter.
I have one for logsplitter force and cycle times. Log splitter questions come up here fairly often. But mine dont look that good, or colored in either:D
   / What GPM hydraulic pump is needed for 2" bore cylinder? #9
I have this one for two stage pumps too....I think it can be useful when matching pump and engine/motor
   / What GPM hydraulic pump is needed for 2" bore cylinder? #10
Boy I am glad I replied to this thread. It is now in my "subscribed" list and It will be easier to find when I need one of these charts. Shure beats doing it by hand or creating another spread sheet:thumbsup::thumbsup:
New/Unused Electric Golf Cart (A57453)
New/Unused...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
2014 FORD F-350 CAB & CHASSIS (A58214)
2014 FORD F-350...
PARKER P-5 VICE (A58374)
PARKER P-5 VICE...
