What GPM hydraulic pump is needed for 2" bore cylinder?
   / What GPM hydraulic pump is needed for 2" bore cylinder? #1
chad22
Kansas
Sears Garden Tractor
I bought one of these cylinders that's in the link for my backhoe that I'm building. It has a 2" Bore. I'm wondering what size (GPM) of pump would I need to make the cylinder have good retract and extend times?
Delvan Ag Pumps Inc 2 X 10 Tie-Rod Hydraulic Cylinder
Thanks
Chad
   / What GPM hydraulic pump is needed for 2" bore cylinder? #2
If you are talking about a small backhoe I would think 5 gallons per minute is about right.
Any pics of the placement of the cylinder would be helpful.
Craig Clayton
   / What GPM hydraulic pump is needed for 2" bore cylinder? #3
Thanks
Chad
Assume 1 in rod,
4 GPM = 2.04 sec extend
1.53 sec retract.
6 GPM= 1.35 sec extend
1.02 sec retract
At 2500 psi, push force would be 7854 lbs
pull force -----------5890 lbs
   / What GPM hydraulic pump is needed for 2" bore cylinder? #5
hey AKK, did you build that spreed sheet? I like it :thumbsup:
   / What GPM hydraulic pump is needed for 2" bore cylinder? #6
I could see some was in there and tried a 2500psi 5" bore....LOL....Tx sylwoody....Yes I make'm.....call it my X-mas gift to ya all....:thumbsup:
   / What GPM hydraulic pump is needed for 2" bore cylinder? #8
Got a little spread sheet here, try that!!
Enter you numbers in the green cells, GPM is a function of displacement and speed in this spread sheet...
BTW, Merry X-mas everone!!
Wow. that makes my spreadsheets look lame. Same results though. I am always comming up with new things to enter.
I have one for logsplitter force and cycle times. Log splitter questions come up here fairly often. But mine dont look that good, or colored in either:D
   / What GPM hydraulic pump is needed for 2" bore cylinder? #9
I have this one for two stage pumps too....I think it can be useful when matching pump and engine/motor
   / What GPM hydraulic pump is needed for 2" bore cylinder? #10
Boy I am glad I replied to this thread. It is now in my "subscribed" list and It will be easier to find when I need one of these charts. Shure beats doing it by hand or creating another spread sheet:thumbsup::thumbsup:
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
TEST YOUR BID BUTTON! (A58374)
TEST YOUR BID...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
