B2710 (B Series) front axle klunking noise......
   / B2710 (B Series) front axle klunking noise......
Once one tooth comes apart, the debris finds itself in the well of the bevel gear case, where the lower shaft bearing is, hence the total destruction of your front axle has been programmed, and for a Kubota dealer to tell a customer to live with the "klunking noise" is blatantly negligent. That's unreal and I wish I could find his post somewhere.
   / B2710 (B Series) front axle klunking noise...... #22
[QUOTE/] I've owned alot of Kubotas and really use them. First thing I always do is tap a zirc fitting on the end of the pastic boot (the thick part). Just drill through it all the way past the metal bushing and a LITTLE into the front drive shaft.
Tap and screw in a zirc fitting.....problem always eliminated. If you haul loads downhill with your FEL in 4WD, prepare to replace the ring (bevel) and shaft
gears at about 800 hrs. Sometimes, better sooner, than later, if ya want to get picky with your dealer, upon receipt on your tractor remover the front wheels and bevel covers and the ring and shaft gears...HAVE THEM X-RAYED by a metallurgist. They manufacture these gears with cracks developing in the teeth during the casting and grinding process. Really bad news..it can kill you too!
Dan Johnson [/QUOTE]
If this problem is as you describe, you would not have "owned alot of Kubotas". I suspect lack of lubrication causing the wear or just plain abuse. You state that the new gears also had flaws, did you ever get a set that did not have the flaws? Perhaps you need to tear the whole tractor down and get everything x-rayed to make sure there are no other flaws.
Think what you want..but there was no lubrication issue. Abuse? What's a tractor for? Bottom line, you guys read all my posts and take note.
   / B2710 (B Series) front axle klunking noise...... #24
Who ever you buy parts for saw you coming, lol.
First of all, the bevel gear and corresponding pinion gear in question are straight cut bevel gears. They are not a matched set, nor does Kubota even sell them as a matched set. Have you even read the Kubota WSM on your tractor?
Second of all, they really took you on the parts. The bevel gear is $276 and the pinion is $147. If you replaced the bearings and seals that adds roughly another $90. So that's a little over $500 a side, not sure how you came up with $2000 to do the job.
I think operator error is to blame here. That same bevel gear that you tore up Kubota uses on the B26 industrial tractors (exact same P/N.) I guarantee if the parts were faulty you would see lots of B26's with front axle problems considering most of them are used commercially and on rental yards.
   / B2710 (B Series) front axle klunking noise...... #25
That was the first thing I thought. Poster needs new sedatives, not new ring gears.
The bevel and pinion shaft gears are a matched set. You replace the bevel gear, you replace the pinion gear. Where are you from? Call Coleman Equipment.
Cost:
42496 09/07/10 6:41:04 PM Shipped $203.51
42219 08/28/10 3:08:41 PM Shipped $130.71
42180 08/27/10 1:25:07 AM Shipped $37.70
42135 08/25/10 4:42:27 PM Shipped $132.61
42107 08/23/10 8:49:39 PM Shipped $70.71
42061 08/21/10 10:40:17 PM CANCELLED $26.73
41798 08/08/10 3:27:25 PM Shipped $246.42
41391 07/24/10 7:55:03 PM Shipped $1,498.99
41345 07/22/10 9:29:23 PM Shipped $367.03
41325 07/22/10 12:48:07 PM Shipped $542.70
41201 07/18/10 4:44:39 PM Shipped $955.69
Sounds to me like you just look at your tractor and do not really use it. All bearing, seals and shims replaced. Differential and pinion gear replaced. All universal joints replaced with new pins. Front propeller shaft covers replaced.
The part number for the matched bevel set is:
Part # 6C070-57210
GEAR-SHAFT(7T,F) 2-5 Day Lead Time
$338.43 2 $676.86
I also bought some new floor pans (rust), rear lights, and a spare front drive shaft (transmission shaft), gears, brgs, and seal just in case that needed replaced.
when the debris from a chipped teeth on the ring gear enter the lower pinion shaft bearing, the bearing fails. The will result in addition bearing and gear failures and possibly even a cracked bevel gear case. Look at the cross section of a bevel gear unit.
   / B2710 (B Series) front axle klunking noise...... #29
Part # 6C070-57210
$338.43 2 $676.86
It did sound like you had the job done in a shop as it normally only costs about 700 to 800 do both! Must have been the extra parts!
On the tires rolling off, inflation to low causing the tires to flatten! This in turn would cause a problem with the lead lag ratio causing the front gears to take extreme load from the lack of balance of the drive train.
tires were never underinflated. never. Happens all the time in heavy snow with no tubes. I did the work myself on my tractor.
2010 GMC Acadia SUV (A50324)
2010 GMC Acadia...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
1240 (A50490)
1240 (A50490)
John Deere turbo 6620 Combine with head (A52128)
John Deere turbo...
1266 (A50490)
1266 (A50490)
